Question about Sony Vaio PCG-9S1L
Configurar el brillo de vaio modelo pcg 9s1l - Sony Vaio PCG-9S1L
3 Suggested Answers
Jaminjimlp
  • 63 Answers
SOURCE: I wish there is someone could help me... my vaio
did you go to sony web site and get the device drivers for your comp? if not do so.... sounds like you have not installed the video card driver .
Posted on May 20, 2011
walesarumi
  • 6993 Answers
SOURCE: I have a Sony Vaio PCG-9S1L that will not stay on
Do you know anyone that uses a Sony Vaio laptop? If yes, borrow a power adapter and test is with your laptop. Also, remove the battery and test is only with the power adapter.
If the borrowed adapter does the same thing then it means the laptop has develop a power problem.
This issue is related to a power problem in as much as the laptop cuts off on it's own.
The problem is consistent with overheating on the power supply board or if there is a defective component on the power board, like capacitor, IC or resistor.
The laptop might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the laptop, thereby not making it to power on properly.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of laptop. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and laptop cuts off on it's own.
This is a common problem faced by many other users too. To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
I hope you understand the above....
Regards.
Posted on Jun 13, 2011
Buenas. compre un router marca D-Link modelo 600. quisera saber si es compatible con la Sony PCG 3A1M no logro que la lapto la acepte.
Le consegui esta informacion de paso por paso como instalar y configurar su router.. Por favor dejenos saber si esta informacion le fue de ayuda.. Pegue el siguiente link en su browser..
http://www.youtube.com/watch?v=LC8GemwkKvU
Si encuentra que esta informaci?n fue ?til a usted, por favor me valora y deja un comentario como esto me favorecer? a hacer el trabajo m?s libre para usted y para otros. Y permiti? por favor que s? si hay otra cosa con que podr?a ayudar usted. ¡Sin comentarios nosotros no podemos continuar ayudando... Gracias por utilizar FIXYA! Los saludos, Junior
Sep 13, 2011 | Computers & Internet
Tip
Telstar CB2194F Rayas horizontales
Este TV usa una tarjeta generica la he visto tambien el algun modelo Sanyo<br />Al encenderlo presentaba una pantalla negra con unas rayas horizontales de colores<br />en la parte de arriva de la pantalla.<br />luego al agarrar brillo la imagen se presenta bien com buenos colores<br />pero con unas rayas finas horizontales en la parte superior.<br />Manteniendoce todo el tiempo.<br /><br />Despues de reemplazar algunos capacitores, el problema se resolvio reemplazando el<br />Capacitor C406 del vertical STV9302A
on Aug 05, 2011 | Televison & Video
Tengo la impresora pero se me perdio el disco lo nesecito
Con la Marca y el Modelo de tu impresora puedes ir a la pagina de la compa?ia de tu impresora y bajar el programa (drivers) para configurar tu impresora
Nov 17, 2010 | Computers & Internet
Neesito driver para una vaio modelo vgn-fs790 para windows 7 el audio es el que neesito
Acá:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFS790&LOC=3
Sino desde esupport.sony.com ingresa el modelo en descarga de drivers.
Nov 09, 2010 | Sony VAIO VGN-FS790 Notebook
Vaio PCG-9S1L Screen is very dark, extremely hard , LAPTOP SONY
As stated in your post "two year old may have dropped it"
If this is true than the backlight has probably been damaged. The small flourescent tubes that generate light through the LCD display.
Email service@lanprotec.com for service options
Mar 01, 2010 | Sony Computers & Internet
No logro configurar la cam por que no tengo el sofwart
mi camara es u-cam modelo ne968 y no tengo los driver k puedo ase este es mi correo para ver k se puede aser inoa240@hotmail.com
Jan 12, 2009 | Logitech Quickcam Chat Webcam
Controladores SONY VAIO PCG5K1L
ok ese noes el modelo, el modelo empiesa con algo como VGN dame ese modelo buscalo debajo de la laptop oh al frente y te dare los controladores.
Nov 10, 2008 | Computers & Internet
PCG-F540 service manual
No hay problema, yo hablo tambien castellano, perdona las falta de ortografia.
El manual de servicio no lo tengo, pero te puedo decir que hay dos maneras de aceder al disco duro del Vaio, dependendo del modelo.
En algunos tiene que remover la tapa que se encuentra a la base del portatil, esta suele ser marcada HD, y se encuentra cerca de la tapa de la memoria RAM. Este deveria de ser su caso.
Aqui esta el diagrama de su ordenadora.
El HD es la pieza 24, y se inesta en el HD Slot, indicado con G:
Oct 19, 2008 | Computers & Internet
Sony Vaio PCG-9S1L Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
