Question about ASUS EAH4850/HTDI/512M RADEON HD 4850 GDDR3 PCI Express x16 Video Card Retail, PCI Express
INSTALLED EAH 4870 DARK NIGHT GRAPHICS CARD ON MY HP COMPUTER
WHEN I INSTALLED THE GRAPHICS CARD ON MY HP MEDIA CENTER PC(m7250N) THE AUDIO NO LONGER WORKED.i HAVE NO SOUND..THE VIDEO WORKS GREAT BUT I HAVE NO AUDIO.. I INSTALLED THE SOFTWARE AS DESCRIBED..NOT SURE HOW THE VIDEO CARD IMPACTED MY AUDIO...I HAVE WINDOWS XP 2005 MEDIA EDITION...THANK YOU FOR YOUR HELP
  • 158 Answers
Does the video card got a HDMI port? in case if you are not using that, you can disable it from BIOS.
Mentioning your mobo model number/sound device would help us to understand and provide a better fix.
let us know the results. thanx
Posted on Jan 20, 2009
The color is not working properly on the computer
Often when colors dissapear the reason is a broken cable, between the computer and the monitor, try another cable / monitor to see if the problem is solved, if not, then the problem is either your graphics card or the settings on your computer, it is possible to adjust them so that you don't get red color for example at all.
Aug 11, 2012 | HP Media Center m7250n (ED842AA) PC...
I replaced th original Ati radeon x300 video card on my hp media center m7250n for a new galaxy gt 240 for better video and also changed the power supply to a new 550 watts. Since I lost audio. The system...
Hello
The x300 is video only.There is a possibility you may have knocked your sound card out of its pci slot while working inside the case.
Check that the sound card is firmly seated in the slot.
If you do not have a sound card and are using onboard sound,reinstall the sound drivers.
Enjoy your new gt 240.
Feb 06, 2011 | HP Media Center m7250n (ED842AA) PC...
Installed Window 7 64bit Ultimate on my HP Media Center M7250n PC desktop. Did express install. Audio problem fixed by reinstalling RealTek driver. Hauppauge sound driver was installed by express...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Nov 14, 2010 | HP Media Center m7250n (ED842AA) PC...
I just lost my video output from my HP m7250n. I tried replacing the graphics card and that did not work. I connected the display with its VGA cord to anther computer and it worked just fine. Any ideas?
This particular model of computer is known to have bad capacitors. If the capacitor that regulates power to the onboard graphic chip is bad, you will not get a video output.
enjoy the power of a PC
Mar 15, 2010 | HP Media Center m7250n (ED842AA) PC...
HP m7250n shuts down unexpectedly.
your power supply is faulty you will need to replace it. If you recently installed a new hardware it could be you don't have enough power to, either upgrade you power supply or remove the hardware.
Feb 27, 2010 | HP Media Center m7250n (ED842AA) PC...
HP Media Center m7250n - How to hear audio steamefrom panel input
You need to unmute the line-in and adjust its level as necessary. Usually you can just double click on the speaker icon in the system tray and the Line In is by default muted and it is on the far right column (depending on your setup). If it is not displayed, click on Options and Properties and put a check mark by Line-in so that it will display.
Feb 11, 2010 | HP Media Center m7250n (ED842AA) PC...
Hi, I just got a new pc HP Media Center M8430F, and I am not able to record stream audio or internet radio
I have an HP with Media Center as well.
Generally you need a software program that specifically records streaming audio and or video. A freeware program I use is OpD2d. Google it and install. Very simple to use.
Apr 16, 2008 | HP Media Center m7250n (ED842AA) PC...
Hi there
Cilck this Link:
This will open the driver selection page.
Select your Operating System, download all required drivers...and finally..... :))
Thanks
Iqbal
Apr 03, 2008 | HP Media Center m7250n (ED842AA) PC...
Color management monitor profile change.
Good Morning aspevak
Depending on the internal video card, you have to install the correct driver for your monitor, and video card, other than that is just setting on control panel and advance setting , all the features, for the colors, or profiles.
Nov 27, 2007 | HP Media Center m7250n (ED842AA) PC...
TV freezes - is it the graphics card?
How much memory do you have installed? Graphics require a lot of memory (ram) to operate correctly. By the time you run the OS, support software, and all the other things on your system, it takes up memory space. Check that first. Even some graphics cards can add memory to them, check that too. My advice is you can't have enough memory in today's computers. Then check all you settings for optimal performance. If you change "one" setting, run your system before you change another setting. That way you'll know what worked.
Sep 11, 2007 | HP Media Center m7250n (ED842AA) PC...
ASUS EAH4850/HTDI/512M RADEON HD 4850 GDDR3 PCI Express x16  Video Card Retail,  PCI Express Logo
321 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
