Question about Acer Aspire One PC Notebook
I have an Acer Aspire One, it froze on me so I turned it of by pushing down the power button. Now when I try to turn on my computer its stuck on the Windows screen. I do not have the DVD. what should I do?
  • Acer Master
  • 2,385 Answers
Re-installtion is required, you may install from external dvd, or by bootable usb
Posted on Jan 08, 2013
  • 24 Answers
SOURCE: aspire 5610 problems with motherboard
Very simply can be some loose hardware.
First thing is to take the battery out and unplug it from the wall. Plug it back in w/o the battery and try turning it on. If it boots great, if not unplug it to shut it off immediately and try turning it on again. Lot of no boot issues are because the system is in a failed sleep/hibernate and just wont get out of it until you do the above.
Try re-seating the RAM (hopefully it's not under the keyboard or somewhere hard to get). The RAM they ship with these units is low yield stuff so even though the RAM is good, and the slot is good, they're not making a good connection cause it's cheap stuff so you may want to try a different RAM chip all together.
Sometimes it can be a loose processor which is usually a lot harder to get to unless your savvy.
Posted on Nov 09, 2008
SOURCE: Acer Aspire One not starting
Corrupt Bios, http://ezinearticles.com/?Acer-Aspire-One-BIOS-Recovery&id=1815776 this fixed mine
Keith
Posted on Feb 27, 2009
SOURCE: Acer Aspire 7520 turns off and on repeatedly
Mine does this but what I found was that if you hold the power button down for about 10 seconds when you are turning it on, it works.
Posted on Apr 02, 2009
joegoldman
  • 335 Answers
SOURCE: Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Posted on Aug 09, 2009
kinerf
  • 27 Answers
SOURCE: acer aspire one stuck on windows safe mode restart
If you have the option of going to a command prompt (on the choose how to start "text" screen), do it, and type at the C:> fdisk /mbr then press the ENTER key. This may fix things. Also, try removing the battery when the computer is off, wait about a minute, then replace it and start computer. This actually helps sometimes.
Posted on Sep 07, 2009
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
3 year old pushed the z power key and computer went into shutdown mode. Now it has no power. I have unplugged it, and held down power key for 30 seconds as suggested by ACER but still no power
shouuld havee restartd when you hold the power button down release and push to start but try this remove the charger and battery from the laptop
then press and hold thee power button down for about 3seconds
replace the battery and charger(charger should be plug into power source)
push the power button to turn on should start up
May 30, 2011 | Acer Aspire m5640 PC Desktop
When i try to update the bios in windows everything froze now i can't restart the laptop the power light go on fan start but no post no image
try discharging the static charge by removing the battery and power cable and then press and hold down the power button for 1 min without battery and power cable connected to the system , then try turning on the system and then tap F2 key as soon as u turn on the system
Jun 27, 2010 | Aspire Acer 7520-5071 Notebook
Hi my acer aspire 9815wkhi will turn on then off
take out the battery and unplug, hold power button down for 40 sec then plug it in and try
Mar 30, 2010 | Acer Aspire 9800 Notebook
Acer Aspire 3610 stuck in sleep mode
When you turn on your laptop do you see the P.O.S.T screen or it just remains blank? and also while booting up do you get any beep sound?
Try to boot your computer in Safe Mode by Tapping F2 (or Del in few laptops) key after pushing Power Button.
let me know what happens.
Askari :)
Mar 27, 2009 | Acer Aspire 3610 Notebook
Dec 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Mar 23, 2008 | Acer Aspire 3100-1405 Notebook
Can't turn it off
hi, ok you only have a few options
hold the power button in for about 10seconds should turn it off.
if it dont then you can remove the battery from the laptop by turning it upside down and theres a slide button to remove it. if you use the laptop on the mains without the battery, all you need to do is pull out the mains cable and it will go off.
to fix problem, go into safe mode, click run, type msconfig. click start up on top right, and untick anything that you dont need loading on startup (if you disable the wrong one it wont do any damage, as long as u only untick ones in that start up group.
Have a nice new year
John
Dec 29, 2007 | Acer Aspire 5630 Notebook
Acer Aspire One  PC Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
