Question about DC Shoes 2008 Dc Balance Snowboard Boot Brown Size 8.5
Closure cable came out of closure dial
Hi, the cable came out of the closing dial on my daughter's boot - how can I fix it myself or where can I take the boot to get it fixed?
thanks,
Sabine
    Problem Solver:
  • 9 Answers
I don't know where you're posting from, but the best place to fix that would be Academy.
Posted on Jan 20, 2009
Hi there, I've got a problem with my Mitsubishi Galant's (2003) release button for the boot. I can open it up with a key, however, the boot's release button by the driver door doesn't work. Is there anyway...
Check for a broken end on the cable either at the lever or in the boot. You may be able to get a replacement inner cable and just push it through or if not then the outer cable will have to be replaced as well. Time consuming but you can do it
Aug 03, 2013 | Mitsubishi Galant Cars & Trucks
Jetta 1.8 2002, sunroof won't close. Opens & partially closes with dial in any position; have manged to ge it to close within 3" of full closure but no further. Tracks are clean and clear. Read...
To reset the motor on you sun roof use the switch to fully open and hold the switch for a few seconds in the fully open position then do the same in the closing position. Worth a try.
Sep 03, 2017 | 2002 Volkswagen Jetta TDI
I left top half way up while cleaning rear galass. now top will not go down. got trunk working & roll bars go up and down. when i unlatch the top i hear nothing. normally you can tell the top is...
first try with disconnect battery ground cable, disconnect cable an leave 2 minute then fix it back and have a look, if not work now it's position uneven, you must close the roof slowly by hand up to locking position after that first operate the switch for closing and let it lock properly then till lock the boot lid to the right position with two flaps then switch off ignition let it stay 5 minute without doing any thing and, after that open the roof, if not work in this way you must fix Mercedes diagnose tool in to the car for manual activation through diagnose tool, and also would like to ask you to check the boot separation flap again is it in the right position if it not close properly it won't work,
Nov 15, 2010 | Mercedes-Benz CLK-Class Cars & Trucks
TRUNK WONT CLOSE
After years of use either the actuator is interfering with closure or the pin assembly has pushed the lock asembley down. May need to be loosened and raised for proper closure around the pin that keeps it closed. Also oiling may free up some funtion of the trunk closure assembly.
Apr 30, 2010 | 1989 Mercedes-Benz 190
Dell Latituse D600 display goes dark
The picture board on your monitor is faulty or bad, since it goes black after few seconds, it means the picture board of your laptop has developed fault.
The best thing for you to do now is to take the laptop to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Dell Latitude D600 Notebook
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
How many fiber optic closures are needed in a 375 km fiber cable?
it depends on the drum length; if your drum length is 4km then you need 94 closure,
thanks
Nasr Kutkut
nasr@kutkut.com
Jan 06, 2009 | 3M Cable Assembly, Fiber Optic Duplex...
Cingular 8525 - white screen
I believe I've figured out what caused my white screen problem. I finally broke down and purchased a nice holster for my 8525. It had a magnetic catch to keep it closed. Within a couple of days I experienced my first white screen. I thought that was pretty wierd, but thought it must just need to be re-booted. Later that night the same thing happened. Throughout the weekend it happened many more times. I got on the internet to see if anyone else was having the same problem...OMG. In site after site the same thing; my 8525 has developed a white screen. I came across one where the writer mentioned that he had just purchased a case with a magnetic closure. I took mine out of the case I'd just purchased, changed the battery, and turned it back on. I have not had a white screen since. I'm back to a velcro closure forever! Good luck.
Jun 11, 2008 | Cingular Wireless Cingular 8525 Smartphone
DC Shoes 2008 Dc Balance Snowboard Boot Brown Size 8.5 Logo
87 people viewed this question
Top DC Shoes Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a DC Shoes Winter Sport Expert? Answer questions, earn points and help others
