Question about Exercise & Fitness
Treadmill just want to know how to lubricate this machine. thinking of buying one
    New Friend:
  • 21 Answers
Sorry, but the description does not indicate what type of machine you are looking to purchase.
Assuming it is a trealmill? Not all machines use belts which need to be lubed any more. AFG (Advanced Fitness Group) uses a belt deck combo which is pre-impregnated with lube for the estimated life of the belt. Landice does not suggest any lube for their standard home use treamills but does make Slip Coat if an additional application were needed.
Traditionally, you loosen the tension on the rear roller so you can access the laminated deck, on which the belt slides on top of. Specific to each brand or model of belt, you will apply either a wax or silicone lubricant. They are usually supplied in a single "dose" or application volume. Apply the lubricant to the deck, retension the belt and start the machine at a slow pace to evenly distribute the lube.
If you were referencing an ellitical, most manufacturers just want the track or beam to remain clean. Cleaning with a light solvent with usually remove any built up. I have found White Lightning (make) Clean Ride (model) wax based lubricant can resolve any noise a good cleaning cannot fix.
Posted on Jan 08, 2013
  • jan thompson Jan 08, 2013
    thank you its a treadmill Vibe life max pro R211. thinking of buying one without a manual and just wanted to know if it needs lub. cheers jan u have been most helpful but if u know anything let me know. it could also be a Lifespan Dominator. lm in australia and would like to know as much about this item. kindest regards cheers jan
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
ercupa190
  • 12223 Answers
SOURCE: Where to buy lubricant for bodycraft treadmill
www.fitnessrepairparts.com
www.treadmilldoctor.com
www.unitedassemblers.com
Posted on Nov 11, 2011
Why does my treadmill stick when I'm running
Vernon, Time to lube the belt,Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY How to lubricate your treadmill belt
Treadmill Belt Lubricant
How to Lubricate Treadmill
Treadmills To lubricate or not to lubricate Insights
Apr 04, 2016 | Nordic Track Exercise & Fitness
What lubricant to use for the belt?
you have to use Teflon silicone lubricant. Also check the video to know how to lubricate the treadmill belt
www.electro-medical.blogspot.com
Oct 30, 2015 | Exercise & Fitness
It has been lubricated. I think the circuit board has crashed, Where can I get a new one?
if you are skeptical about buying on ebay or amazon then here's a more trust worthy supplier of these treadmills
http://treadmillmachine.net/shop/nordic-track-ifit
Jul 08, 2014 | Nordic Track NordicTrack Treadmill, A2550
Oiling a vibe life max pro r211 treadmill
use the video how to do it. Good luck, and God bless you
Jan 08, 2013 | Exercise & Fitness
Tunturi t80 treadmill gives check lubricant message after multiple times of lubricating the belt
RESET the machine. Use your owner manual read section troubleshooting and proceed according.
God bless you
Aug 02, 2012 | Tunturi T80 Treadmill
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
Aug 20, 2011 | Exercise & Fitness
Need to lubricate the bell of my treadmill . how i do that..?
you will need silicone lubricant with an applicator wand and all you have to do is lift the belt up enough to get the applicator wand under and spread the treadmill silicone on the machine - be very careful that you do not use any other silicone except what is made for treadmills. My company sells this product for $18.95 and it usually will last 1-2 years with proper lubrication
Aug 05, 2010 | Nautilus Commercial Series T916 Treadmill
Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
May 27, 2010 | Tunturi T20 Folding Programmable Treadmill
Pro-Form 360P, when I step on the belt, it stops moving.
when the belt is stopped you should be check the deck if this it´s worm or the walking belt, because a probable cause is lack of lubrication, In addition should send the engine to revision, because according to what your gross probably already there are some Diode Rectifier damaged, You must know that the cause that generates this problem stems from the walking belt and the table or deck
Jul 16, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
91 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
