Question about Exercise & Fitness
Oiling a vibe life max pro r211 treadmill
Just would like to know how to lubricate his model. lm thinking about buying a 4yr old second hand treadmill with no manual
  • jan thompson Jan 09, 2013
    i cant thank u all so much! love this wonderful site, what a great bunch of people wanting to help each other. hope l can help someone too. cheers jan from OZ!!!
    Top Expert:
  • 12,223 Answers
Use the video how to do it. Good luck, and God bless you
Posted on Jan 08, 2013
Testimonial: "thank you this was very helpful!!!"
bunnydawg
  • 5158 Answers
SOURCE: I have a sears proform 585 treadmill.
if it is a plastic belt do not put any oil near it as that degrades it
Posted on Jan 23, 2009
SOURCE: I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Posted on May 18, 2009
SOURCE: roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Posted on Dec 01, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Posted on Sep 24, 2010
How to lubricate a precor treadmill belt?
About This Video
Video about How to Lubricate a Treadmill using Liquid Lube
  • This vidoe will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • To begin, clean the deck and belt by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt is loose you can take an old towel and place it under the belt as shown in the video. Move the towel up and down the deck, then using your hands pull the belt around half way to ensure you have completely cleaned the back of the belt. Then remove the towel.
  • Open your lube packet and use half of the package to make a half circle on the deck, from the front outer portion of the deck toward the center and then back to the outer edge. Use about half the package for this arc. Now repeat the process on the opposite side. Be sure to wipe up any excess oil as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the lubricant out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously.
  • Power on and start the machine and let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes todays demonstration of how to lubricate a treadmill using the liquid lube.
How to Lubricate Treadmill Using Liquid Lube Video
Apr 30, 2014 | Precor 9.21 Treadmill
Hi, I'm thinking of buying a second hand treadmill
the best way is you ask to the owner how much is the cost?. He know very well. or ask to the www. fitnessrepairparts.com for to get some idea
God bless you
May 20, 2012 | Exercise & Fitness
What lubricant can i use for my pro form tredmill model 380 E?
You can use silicone lubricants.
But if you want buy lubricants:
go to www. treadmillpartszone.com
or www. gympart.com
sincerely.
E.CUADRA
MANAGUA,NICARAGUA. C.A
Nov 23, 2011 | Tunturi T20 Folding Programmable Treadmill
I have a pro form treadmill and it seems like the belt is sticking, its about 14 yrs old. I think I might need to replace the belt
kilgore511,
The most common cause of belt sticking or "slippage" is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
If you have found this helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
Just purchased the nordic track 2550 pro treadmill and was wondering if you had to lubricate the belt, i was told that it was self-lubricating and never needed oiled.
You do not need to lubricate the belt, unless you speek with or read something from Nordic trac. Oiling wont hurt anything, but is not needed.
Dec 29, 2010 | Nordic Track NordicTrack A2550 PRO...
It stops after 1hour and 40 minutes of running how do I get it so I can go longer?
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Jul 05, 2010 | Nordic Track NordicTrack A2750 PRO...
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Proform Treadmill doesn't run constant speed.
You have a friction problem between your belt and deck. A treadmill of this age either came with a waxed deck, or requires periodic silicone lubricant spray on the deck. You can check your owners manual to see which type of surface your machine has. Typical belt life on a consumer grade treadmill is about 2 to 3 years. If you purchase a new belt from the manufacturer it will come pre-lubricated.
Jul 23, 2008 | Health & Beauty
Exercise & Fitness Logo
173 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
