Question about Acer Aspire Z3100 (2771498) 21.5 in. PC Desktop
High pitch screeching on my pc cannot fix thru speakers check ok
Tried fixing if i use volumn higher than 50 percent screeching
  • Acer Master
  • 27,725 Answers
Unusual noises coming from your computer can mean anything from serious trouble to no problems at all. The uncertainty, together with the expense of computer hardware components -- not to mention the risk of losing data and being without your computer -- make it important for you to investigate any unusual sounds as soon as they come to your attention.
Normal Sounds
Not every high-pitched sound coming from your computer suggests a problem. Computers also generate a variety of sounds as part of their normal operation. In particular, anything that spins can easily make noise. This includes cooling fans and the hard drive. In the case of fans, their sound sometimes grows louder when the computer works harder because it needs to run the fans at a faster speed in order to dissipate the extra heat from the higher level of operation. You probably don't need to concern yourself with an unknown high-pitched sound unless you have used the computer for a while and the sound is new. b> Capacitors Capacitors sometimes make a high-pitched buzzing sound, either when under a high load or when defective. In the latter case, faulty construction can cause gas to build up inside the capacitor, which then vents under pressure and sometimes creates an audible noise. Defective capacitors can damage or destroy other hardware. f you suspect a bad capacitor, or don't know what else it might be, give your computer an inspection. b> Capacitors Inspection b> Your computer has capacitors all over it, including on the motherboard and on nearly everything that plugs into the motherboard, so tracking down a bad capacitor can take some time -- especially if you don't know whether a capacitor is actually causing the problem. Many capacitors look like tiny little soda cans and smaller ones look like squat cylinders. Failed capacitors usually bulge out at the top or have crusty residue around them. Be sure to check not just the motherboard but also any other hardware components with visible capacitors on them. If you find a bad capacitor, keep looking in case you find more. Afterward, don't use your computer again until you repair or replace the faulty hardware. Fans b> The bearings and motors on fans sometimes go bad. If this happens then the fan may begin to whine, whether or not it stops working. If feasible, open the side panel of your computer tower with the system running and try to pinpoint the exact source of the sound. If you can determine that the noise is coming from a fan, power down the computer and replace that fan. b> Power Supply Unit b> Power supply units sometimes make a high-pitched whining or droning sound; it can happen continuously, when you perform certain tasks on the computer or when you take the power load high enough. This can happen either because of cheap construction or because the unit is too close to maximum capacity. As you would do to check the fans, open the side panel while the computer is running and put your ear up to the PSU. If this is where the noise is coming from, replace the unit with a high-quality model and upgrade to a higher power output if you need to do so. Hope this helps.
Posted on Jan 08, 2013
Screeching sound from Bose 901 Equalizer
Check the treble on the EQ, is it possible to take a pic of the equalizer?
May 27, 2013 | Audio Players & Recorders
How yo stop screeching thru my speakers
re-installation of sound drivers may solve the issue, otherwise the speakrs of the system needs replacement
Jan 08, 2013 | Acer Aspire Computers & Internet
LG ht 303 no sound, internal high pitch sound
Search on Google its Good sarch Engine.Try It after cant solve than post on this sites .Ok//
Jul 29, 2012 | LG HT303SU Theater System
I always have too turn on the mic volume from volume control before i start audio chat. by default it is off. could u help me in fixing this . Model : Acer Aspire one d150 1669.
hi the reason this is is because you could be playing loud music and the mic could pick it up causing a screeching sound (you probably heard this when a mic is next to a speaker) and because this is such a small unit it is inevitable you can set it not to turn the mic down but if you do it will damage your speakers as it will either screech and when it decent 80 percent of the time it still is but we cant hear it and it really damages both mic and speakers that is why it is set like this by default i also have one of these computers and it is because they are so small the mic and speakers are really close so they have it set like this to prevent damage i hope you understand my exploration OK and i hope that this has helped thanks please contact me if you require more info on your net book as i can help you with anything regarding
Jan 14, 2011 | Acer Aspire One PC Notebook
Hi, I'm driving a 04 honda accord euro, and I've replaced the old standard speakers with a new one, sorry that I forgot the brand of the it. Recently I heard some high-pitch noise coming out of the...
sounds like alternator whine, can be a hard thing to fix or something really simply. here are some things to try: check your ground at the battery first, make sure it's a good connection on the battery and the bolt it's grounded to on the car, make sure the battery connections are clean, positive and negative. make sure you have a "good" ground on your amp/amps and radio. you can also try grounding the radio and amp at the same location to avoid "ground loops" don't run a long ground from amp, but run a wire from the radio to the amp ground. hope it helps. dave
Oct 05, 2010 | Car Audio & Video
Laptop gives off a high pitched screech ONLY upon start ups
Assure there a no disks in your CD/DVD drive
Make sure there is nothing blocking the fan
Feel the base of you laptop and assure it is cool
Do not block off air flow
Event Viewer: Click the Start button . In the Search box, type Event Viewer, and then, in the list of results, double-click Event Viewer.
Go to the Sytem Tab - Look for any errors that seem noteworthy
Post your results
Jan 07, 2009 | Sony VAIO VGN-NS110E/L Notebook PC
Packard Bell speakers screeching sound
Are they plugged in to correct sound socket on back of computer
even if they are on monitor
Jul 05, 2008 | Packard Bell Speaker Computer Speakers
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
Hissing in speaker
I would contact http://www.simplyspeakers.com amd see if theres a repair thats feasable to do with this speaker and tell them what you got and what you wanna do and they will assist you in getting the speaker fixed or replaced with what you want and for the price you want. Good Luck
May 12, 2006 | Alpine Type-R SPR-17LP Coaxial Car Speaker
Acer Aspire Z3100 (2771498) 21.5 in. PC Desktop Logo
487 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
