Question about Lands Phones
I have a new Panasonic KX-TG4771C. The base set...display screen will not stay lit? The portable one stays lit!?
Got tis new for x-mas. Base screen lites up but only stays lit for approx. 1 minute!
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
jessee007
  • 310 Answers
SOURCE: no link to base Panasonic KX-TG2357
are you running a wireless router? try unpluging router to test phone.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
SOURCE: Phone says I am too far away from the base--panasonic kx-tg2356s
unplug the base unit and when you plug it
back in the handset should work
Posted on Feb 07, 2009
SOURCE: Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Posted on Mar 23, 2009
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Jan 23, 2010 | Panasonic Lands Phones
No link to base
It sounds like you may be getting interferance from somewhere. Try moving the base unit to another location. Avoid putting by other electronics. T.V.s, microwaves, and such can mess with the signals. Hope this helps Good Luck!
Jul 24, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
Base Unit unable to use
Your base has taken a strike to the processor and it is stuck trying to boot up. If you have cycled the power already and it stays stuck, it is not going to boot. Buying a replacement base (you can get just the base a little cheaper than the base/handset combo) and recycling your old one properly is the way to go if you want to get your base up anytime soon. Once you get a base, you will register your handsets to it, and reset your answering machine greetings, etc. If you have stored settings in your handsets such as the dialing directory, those will still be there. Just google "cordless telephone repair" and the first couple non sponsored links carry the base only. Good Luck
Jan 09, 2008 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Lands Phones Logo
166 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
