Question about HP LaserJet 1320 Printer
What is print density - HP LaserJet 1320 Printer
  • Terri West Jan 08, 2013
    Thanks Tom. Any idea how to increase it on a LaserJet 1320?
    Top Expert:
  • HP Master
  • 36,279 Answers
It is a measure of how black the print is on the page
Posted on Jan 08, 2013
After printing 5 pages, My printer will showing density low K , and stop printing. Density low K)
K would indicate issue with density of black toner or ink. Check your supplies status to make sure it is not a simple as an empty black cartridge.
May 17, 2015 | Office Equipment & Supplies
C7180 poor print quality
  • You printer may be running low on toner or the print density is too low.
  • Set the print density higher
  • Try turning printer off and on.
  • Print
Hope it helps.Thanks!
Sep 26, 2011 | Office Equipment & Supplies
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Dec 09, 2010 | Tektronix Phaser 740P Laser Printer
How do I get a darker print?
when you click to print a document it has properties next to the printer click on this then set the print quality to best it will come out darker!!
Apr 08, 2010 | Dell Photo 964 All-In-One InkJet Printer
Hp m3035 won't print page comes out warm but no toner
Load paper in tray 1. Print a few pages, as it's printing open the top cover, remove the toner, look at the paper in the printer. Does it have printing on it? If it does, the laser/scanner is working. It could be the transfer roller, it could be Hi Voltage Power Supply. Look in Print Quality Menu/Toner Density. Increase the density.
Mar 10, 2010 | HP LaserJet M3035 MFP Printer
How do I change the toner density on the push button display when it is locked with an * We have low or a feint print out of the fine print on the print settings print out test sheets. I have cleaned all...
A new laser could help, but you should make sure the toner save is turned off, it makes toner last longer by making light prints. Toner save is set in printer properties in the control panel
Sep 10, 2009 | Brother HL-5240 Laser Printer
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
<ESC>%-12345X@PJL DEFAULT DENSITY=4
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
Or:
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Apr 23, 2008 | Zebra LP 2844 Thermal Printer
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1320 Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
