Question about Frigidaire Ovens
Oven not heating Kitchen Aid KEBC207KSS04
Lower oven turns on (at least digital displays shows it's starting the process) but digital display never shows a temp. and oven never heats. Upper oven works and digital panel works. Any ideas before I call for a repair??
5 Suggested Answers
  • 236 Answers
SOURCE: lower oven not heating
the element has probably blown.
Posted on Mar 13, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
Posted on May 24, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
heatman101
  • 43501 Answers
SOURCE: GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I want to use top and bottom ovens but at different temps - how do I do this
    To Set a Cook T ime:
    1. On double oven models only, press UPPER OVEN or LOWER
    OVEN for the one you want to set.
    2. Press BAKE or CONVECT UPPER (on some models).
    Press the number pads to enter a temperature other than the
    one displayed.
    3. Press COOK TIME.
    4. Press the HR and MIN "up" or "down" arrow pads to enter
    the length of time to cook.
    5. Press START/ENTER.
    The start time and stop time countdown will appear on the
    oven display.
    On double oven models only, when both upper and lower
    ovens are being used at the same time, touch UPPER OVEN
    or LOWER OVEN to display the respective cook time.
    When the stop time is reached, the oven will shut off
    automatically and "End" will appear on the oven display.
    If enabled, end-of-cycle tones will sound, then reminder
    tones will sound every minute.
    Repeat the process by choosing the other option of UPPER or LOWER OVEN
    Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
    Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
    Below is the complete instruction sheet.
    You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
    PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
    mode and verify the error codes. Ensure AM software, UI software and EEPROM
    CHECKSUM versions appear on the lower text line. If AM software and EEPROM
    versions do not appear, UI and AM may not be communicating. Verify this for the
    lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
    the AM software version for the lower oven appliance manager, and the microwave
    UI will show the AM software and EEPROM versions for the microwave appliance
    manager.
    If the lower oven UI is not displaying the AM software version, go to UI IS NOT
    DISPLAYING AM SOFTWARE VERSION.
    If the upper oven UI is not displaying the AM software and EEPROM versions,
    go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
    EEPROM VERSIONS.
    If lower oven UI and microwave UI are both displaying an error, go to LOWER
    OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
    UI IS NOT DISPLAYING AM SOFTWARE VERSION:
    A. Unplug oven or disconnect power.
    B. Open the back panels and make sure the P6 and P2 connectors are fully
    inserted on the appliance manager and on the lower oven user interface board.
    - If they are not plugged in, plug in connectors and go to step F.
    - If they are plugged in, go to step C.
    C. Visually inspect all wires between P6 on the appliance manager and P2 on the
    lower user interface.
    - Make sure wires are not cut or pinched.
    - If the wires appear to be intact, perform a continuity check between
    P6-1 of the appliance manager and P2-1 of the user interface board.
    Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
    P2-5(UI). All the measurements made should be less than 5 ?. If any of
    these measurements exceeds 5 ?, go to step E.
    D. Replace the appliance manager. Ensure all connectors are properly inserted.
    E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
    F. Replace all parts and panels before operating.
    G. Plug in oven or reconnect power.
    H. Observe for longer than 1 minute to determine if error has been repaired.
    I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
    1 minute.
    - If no error occurs, cancel the cycle, the problem has been repaired.
    - If error occurs again, restart the troubleshooting procedure at step A.
    At step D, replace the lower oven user interface board if appliance
    manager has already been replaced.
    - If both are replaced the problem has been repaired.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    May 22, 2011 | Ovens
    Oven displays "Supply Open Neutral" What does
    I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
    Nov 29, 2010 | GE Monogram® ZET3038 Dual Single Oven
    Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Aug 24, 2010 | Thermador SC302T Electric Double Oven
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    May 24, 2009 | Jenn-Air Electric Double Oven
    Kitchen Aid Double Convection Oven blows circuit breaker
    the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
    Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
    heatman101
    Jul 30, 2007 | GE JTP48 Electric Double Oven
    Ovens Logo
    Top Frigidaire Ovens Experts
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Starnley Johnwells
    Starnley Johnwells
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
