Water is dripping from our inside unit of Daykin split system air conditioner
Split system air conditioner
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
Your condensation line maybe clogged
Posted on Jan 08, 2013
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
SOURCE: Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Posted on Jan 29, 2008
SOURCE: Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Posted on Aug 14, 2008
SOURCE: leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Posted on Dec 31, 2008
Air conditional water drip
That happened to us. It was a broken pump, pump was up in attic. attached to our inside air-con unit. We had it fitted on an inside wall of the house, and so a pump must be installed to take away the condensed water to the outside of the house. Hindsight being 20/20 I would never buy one that needed a pump to get the condensed water out of the house. We would have put it an outside wall where the water goes straight outside, no pump needed. Our First pump lasted just over 2 years so warranty was expired. Cost us over NZ$500 to have new pump installed. Never again. Only attach your unit to an outside wall, even it looks prettier on the wall where it would need a pump. Bottom line:- Don't touch a pump. Pump was cheap but labor cost for serviceman astronomical! Bet of luck.
Apr 20, 2014 | Sanyo Split System Air Conditioner
Water flushed from unit inside the room instead of beeing flushed outside throw the out let pipe
Possible that the tilt is more to the front that makes the water drip down. Another reason is that the drain pipe can be clogged with dirt build up and so it flushes back.
Finally if the evaporator is dirty and clogged due to dirt accumulation the water might drip down to the front.
So please check you filter, use high pressure air on to clean and reset the panel.
Aug 27, 2011 | LG LSC121PMA Split System Air Conditioner
My split system R/cycle air con is dripping water drops from the inside unit.
hi,
If this happens just recently, most probably the cause of dripping is that there is something that blocks and restricts the condensate line and it causes the water to overflow and drips.
Try to check the line if it is free from any obstruction.
Hope this help you.
Don't forget to rate me. Thanks...
Regards,
John
Jan 12, 2011 | Heating & Cooling
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
The indoor split system is dripping water what can i do?
There should be a drain pipe to send the condensed moisture outside. Take the cover off the unit and check where the tray is and unblock the pipe.
Oct 05, 2010 | LG LSC121PMA Split System Air Conditioner
What is the open air or closed air switch do? --I have an older GE wall air conditioner in an apartment---I hear water gurgling--outside --but there is no dripping--Thanks!
The outside setting is for bringing in the out side air,the closed keeps the air from the ac circulating and closes outside air off.The unit needs to be remove and took out side and cleaned out with a water hose,dirt and debris is keeping it from dripping out side,
Jun 05, 2010 | GE Quiet-Aire Ductless Split System Air...
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Condinsate Water Leaks Inside Trailer
Where is it dripping from inside the trailer? is a tray under the unit filling up? why does the line drip? where from? is it split? have you put a color dye in condensate to check flow what temp have you got inside your trailer when A/C off?
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Leaking water from inside samsung split sytem
Dec 31, 2008 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
