Question about Panasonic CT-27SF25 27" TV
Green tint on screen hue adjustment will not clear up
32 inch westinghouse LTV32W6HD. I HAVE BEEN THRU THE WHOLE HUE SPECTRM WITH NO SUCCESS. PLEASE HELP.
    President:
  • 3,130 Answers
You will need to get the service manual and go to the service menu and perform the screen and drive alighnments. Good Luck
Posted on Jun 30, 2007
SOURCE:
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Tv screen is high in green color what settings do I need to be on
If your TV has a color temperature setting; it is probably on medium. Try it on warm. This will decrease the amount of green and increase the red.
Otherwise you will need access to the tint/hue controls; adjusting it more toward red will help.
Dec 21, 2014 | Televison & Video
Westinghouse LTV32W6HD 32 in. LCD blinking pink screen
Sounds like a T'Con fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 01, 2014 | Westinghouse LTV32W6HD 32 in. LCD...
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Color and tint looks different. There is a green hue to the screen, and adjusting the tint and color does not help.
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
May 10, 2010 | Insignia IS-LCDTV32 32 in. Television
Mitsubishi wd62530 green tint on bottom of screen
If you used the exact replacement lamp then your tv has a defective light engine, call mitsubishi and make noise they might be willing to help with the cost- around $800 to $1200
Dec 10, 2009 | Televison & Video
Have a blue tint or hue on the screen of my Hitachi 50vs69 television. The tint does not cover the whole screen just an irregular pattern near the middle vertical axis of the screen.
The Optical Block is causing this. Due to the cost of replacing I would call Hitachi at 1800-448-2244 and see if they would be will to help you with the cost.
Hope this helps,
Skyassoc
Jul 17, 2009 | Televison & Video
HDTV tube television - with green tint on right half of screen
i had the same prob on my 28 inch hd sanyo crt , i took it apart and reconnected a few plugs and havent had any trouble yet { be sure to unplug it and b quite careful even then} saved me a couple hundred $ !!!
Nov 19, 2007 | Televison & Video
Panasonic CT-27SF25 27" TV Logo
139 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
