Question about VIA Asus A8v-e Se Socket 939 Pci-e K8t890 Motherboard Send By Ems
A8VE-SE won't recognize SATA HDD
Won't recognize SATA HDD
  • 32,281 Answers
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Posted on Jan 08, 2013
BIOS won't recognise SATA hdd.BIOS is Pheonix-Award BIOS v6. 00PG. Do you think I need to update the BIOS?
Hi, according to your mobo manual it supports SATA1/SATA2 hard drives so it's recommended to update BIOS, the latest I found it has release date 2006-06-29, you can find it in the folllowing link: Support For K8MM MSI Global
Nov 07, 2017 | MSI K8MM-V Motherboard
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
Oct 08, 2012 | Computers & Internet
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I want to install xp sp2 on Sata HDD The motherboard is P5RD1-VM but there is error set up did not find any hard drive plz tell me settings of bios to sata compataibale
It's likely a problem with your connection cable from the HDD to the motherboard. The bios shouldn't have to be set up for the HDD to be recognized through a sata port.
Jul 17, 2011 | ASUS P5RD1-VM Motherboard
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
My Sony VAIO VGC-RA920G won't recognize my replacement HDD.
You first should check to see if the SATA cable is plugged in to the HDD all the way. If not, there will not be any data flow. If it is, check to see if the power cable is plugged in. If not, it's not using power or getting data flow.
May 09, 2011 | Sony VAIO VGC-RA920G (R04FA1DTA) PC...
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
VIA Asus A8v-e Se Socket 939 Pci-e K8t890 Motherboard Send By Ems Logo
213 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
