Question about Plumbing
Our Aqua Source single handle faucet will not spray water after switching from sprayer to full stream.
This is a newer kitchen faucet and this problem has happened a couple times before, but we always got the water to flow again. This time we've tried several times, but cannot get water to flow after switching the stream from full to spray back to full. The water stopped when switching back to full. Now nothing.
  • 3640 Answers
SOURCE: We have a fancy single
does the faucet have an aireator on the end of spigot. if so remove by turning off with pliers, and see if it is blocking the water. if it is, clean aireator and replace if necessary.
Posted on Jan 15, 2011
arealplumber
  • 33 Answers
SOURCE: Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
  • 653 Answers
SOURCE: The handle on my kitchen faucet falls down and
There should be an Allen screw on the underside of the handle. Loosen it to take the handle off, then tighten up the packing nut with a channel-lock wrench.
Posted on Sep 13, 2009
packrat1948
  • 528 Answers
SOURCE: Have a Blanco single-handle pull-out faucet with
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Posted on Jul 01, 2011
kk0007kay
SOURCE: Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
Posted on Apr 21, 2012
Kohler sprayer with forte single handle, will not spray well. When sprayer is on the flow to faucet cuts off but there is only a small amount of water coming out the sprayer.
Check to be sure the hose isn't kinked somewhere below the faucet. If there aren't any kinks there is likely debris stuck behind the nozle screen, remove it and clean it- or your handle mechanism is broken. Replacement handles and hoses are fairly inexpensive if you need one they're easy to find at most big hardware stores or on Amazon
Sep 05, 2013 | Kohler Kitchen Faucets. Forte 1-Handle...
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
When the water is turned on, the faucet "sputters" and "hammers" as if the water had been turned off then back on when it hasn't been. Plumber says we need new part (inside cartridge 070807-Aqua Source)....
The USUAL cause of this is the diverter valve that channels the water to the sprayer. There are several types of these so search for yours in google to find a blow-up drawing of it. They are usually in the tower the spout swings on and sometimes are a pintle valve like a little rod with dumbells on the ends. Crud can make them not seat then they will cause the hammering.
Mar 09, 2010 | Danze D403412 Melrose Single Handle...
Moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
Feb 23, 2010 | Moen ShowHouse S711 Waterhill Single...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
  2. Remove handle.
  3. Remove top cap.
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
185 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
