Question about Sharp AR-5316 Advanced Digital Imager Copier
L1 is flashing and the photocopier is not working
It's a sharp AL 1553
    Problem Solver:
  • 8 Answers
It's the lamp
Posted on Mar 01, 2009
    Novelist:
  • 126 Answers
.****MAKE SURE THE POWER IT OFF AND UNPLUGGED FROM THE WALL FIRST *******
This is a scanner problem - didn't leave or come back to home, scan overload or cable off or drive problem. Try to unlock the scanner from it position ( Remove platen glass and move the scanner unit from it position)
Posted on Jan 20, 2009
How do i reset a sharp al-1553 photocopy
Try unplugging it for 20 minutes. If that doesn't work, go online type "sharp al1553 user manual" and it will show sites to get manual. Use the trouble shooting section.
Apr 28, 2016 | Sharp Office Equipment & Supplies
We have a sharp AL 1553. It is flashing 1-L. I cannot find out what this fault means or how to fix it.
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Good Luck and Thank You for using Fixya.
Jan 17, 2011 | Sharp AL-1553 Black and White Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
My Sharpe Al-1553 keeps flashing L and won't work
This is a fatal error with the scanner. It is most likely to be a power supply or positioning error with the scanner not having returned to the home position or the positining sensor. You will need a service engineer call to rectify this.
Sep 24, 2009 | Sharp AR-M205 Copier
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
