Question about Dryers
Dryer will not run
Dryer will not turn on seems dead?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 54 Answers
Have you checked the panel (it will be a double switch) The other option would be to check the power button on the dryer
Posted on Jan 08, 2013
My dryer is dead. I have ohmed out the cord and changed the dryer control board (8546219). Still dead, nothing at all. Any other ideas? I have checked the fuse and it is good. I had a local repair man look...
hello again,
no thier doesn't seem to big issue with with reconditioned control panels in fact i dare say yours is good since the dryer didnt start with the original one and still wont start with the one you have replaced. having checked teh thermal fuse to be good and with basically 2 control boards yet the dryer doesnt run it seems very possible the motor is going to be the problem...not sure what led ya to the control board yet it the drum doesnt turn the very part that turns it when power is applied to,if it has powewr to it and doesnt turn the drum it would seem to me its bad....dont get me wrong on this but its like having a broken leg and going to the doctor and saying i believe that my heart is weak since my legs hurts and totally disregarding the broken leg
GENE
Oct 04, 2011 | Kenmore Elite HE4 Electric Dryer
Was drying cloths yesterday and restarted it due to the cloths not being dry set it on the hottest setting, went outside and came back in and dryer was stopped...checked the breaker switch, thought it may...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Magic Chef Dryers
Dead dryer - fuse location mede300 maytag dryer purchased 2009
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 08, 2010 | Maytag MEDE300V Dryer
Kenmore 110.77741600 Gas dryer- Klunking..Now dead then dead...
belt may have broke or something in the blower housing.
Oct 09, 2009 | Kenmore 63942 Dryer
Whirlpool duet dryer does not run
You did not say if the motor is running, I have to assume that it is not.
You can try this...
Turn off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Then turn your power back on and push the start button.
Sometimes motors will get a dead zone in them and this will move it from the dead zone.
If that doesn't help then you need to check a little farther into why it is not working.
Could be a faulty motor, faulty start switch, broken belt, or maybe a faulty timer switch.
I hope this helps
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer will not start
Check and make sure you have electric going to the dryer.
If you do then listen closely to make sure the motor is not running, sometimes the belt will break and the motor is almost silent when running.
If the motor is not running, it could be your start switch,timer switch or maybe your motor is faulty.
Another thing you can try is make sure your power is off to the dryer, reach inside the drum and turn the drum 1/4-1/2 turn. Then turn your power back on and see if it works then. Motors will sometimes get dead zones in them and this will rotate it out of the dead zone.
I hope this helps
Oct 01, 2009 | Kenmore 600 6962 Dryer
Dryer will not start
Check your electric going to the dryer to make sure you have power to the machine.
Then check to make sure you motor is not running, sometimes with a broken belt the motor is almost silent when running.
If the motor is not running then your problem may be the start switch, timer switch, or the motor could be faulty.
One thing you can try is to make sure your power is off to the machine, reach in and turn the drum by hand 1/4-1/2 turn. Turn back on the power and try to push the start switch again. Sometimes motors will get dead zones in them and this will move it out of the dead zone.
I hope this helps
Oct 01, 2009 | Maytag MED5600TQ Electric Dryer
Lg electric dryer has no power
Try to reach inside the dryer and turn the drum by hand, sometimes the motor has a dead spot and will not run...some times this helps to move the motor out of the dead spot
Sep 23, 2009 | LG DLE2514 Electric Dryer
The dryer drum won't turn. Everything else seems
If you can hear the motor running when it is turned on then you dryer needs a new belt. If you cannot hear the motor running it needs a new motor.
Apr 11, 2009 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
