Question about Whirlpool Duet GHW9150P Front Load Washer
Cracked door window and hinge - Whirlpool Duet GHW9150P Front Load Washer
    Sergeant:
  • 291 Answers
Http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-GHW9150PW0/1198/0153200/W0501061/00002?blt=06&prst=&shdMod=
Posted on Jan 08, 2013
Broken door on front load washer, Door cracks on side mounted to machine by hinge.. Second door cracked in same spot
Not sure but check with the manufacturer, there may be a recall notice for this problem.
Jan 17, 2015 | Washing Machines
Why is door still open at top after replacing door hinges on Whirlpool WFE510S0AW0
Well, I assume you have the door hinge clips in the right position,
and the door is seated properly with that 2mm slot that sits on the hinge receivers. If hinges are replaced, then it must be hinge receivers.If the door is crooked, moving the hinge receiver will align the door. Besides hinge receivers should be replaced first, before the hinges, that in my experience rarely break
I dont like the bent twisted story. I bet the little plastic U-roller in the hinge receiver is worn down or cracked. Fix is to replace the hinge receiver (a secondhand one is in plentiful supply) - or find a look alike roller and fit it. Cord pully's at the local hardware store may fit, window slider tracks, or even coins with a small 1 inch by 4mm bolt as an axle will do the trick.
Still not sure. Remove the dorr using instructions, and set aside.
Remove hinge receivers from each side. Are the little wheels in there good, or wobly, worn of missing?
Problem Fixed
May 22, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Why driver side windows for a 1996 toyota corolla dx are not working
It is the wire
bundle in the driver door. As you open and clos the door, the wires flex in
the hinge area. You have one broken wire. The rest are ready to break.
The insulation has dried out, and where it cracks, there is excessive
bending at the crack when the door pivots. You need to splice and solder
the broken one and then wrap the other cracked wires with electrical tape,
one at a time and also wrap around the bundle. This probably requires
removing the door (I had to), but maybe if your fingers are tiny enough you
can just get away with removing the door panel and the driver's foot panel.
Good luck realigning the door if you take it off.
Aug 08, 2010 | 1996 Toyota Corolla
07 Chevy Silverado 2500 HD LT door problems
What your hearing is the door stop which needs some lube. You should be able to accomplish this from the out side using grease or white lithium. The mechanism in the middle of the two hinges is the door stop and keeps the door from opening to far.
Jul 09, 2010 | 2007 Chevrolet Silverado 2500HD
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Power window problem on 1500 dodge ram
Check wire loom coming through to door at hinge end of the door from pillar, and see if you have power going that far to switch. Not uncommon to find a worn, cracked, or broken wire in that loom where it bends constantly with opening & closing door.
Oct 06, 2009 | 2004 Dodge Ram 1500
My Kenmore HE dryer door handle has cracked. How
Carefully remove the door from the dryer by removing the screws from the hinges and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
Searspartsdirect.com has some excellent exploded view diagrams that you can work from as well.
If you have questions, please let me know. I hope this helps you.
Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kitchenaide KGST307 cracked inner oven window.
Open your oven door and look at the hinges. You should see a drop down thumb lock on each hinge that you pull down and after you do so, lift up on the door as to close. The door will catch on these thumb locks and then at this point continue to lift up on the door as you pull the door out at the bottom. Reverse directions to reinstall.
Apr 05, 2009 | KitchenAid KGST307 Gas Kitchen Range
Window dryer
Okay...thank you for the feedback. This repair will be much easier if you remove the door from the dryer. Just loosen the screws on the hinge where it connects to the dryer door opening. That is...remove the door with the hinge still attached. CAUTION: Make sure you support the weight of the door as you loosen or tighten the door hinge. Lay the door face down on a soft surface like some towels. Locate the screws on the door interior. There are a series of them that go around the perimeter of the door. Removing these screws will enable you to disassemble the entire door. The interior door facing will come off, allowing access to all the remaining parts. Just make sure you remember how they come apart. If you get confused, you can go to searspartsdirect.com. Type in your model number and locate the "Door Parts" heading on the next page. There should be an illustration on how the door is assembled. I hope this helps you. If you need further assistance, please post back and let me know.
May 24, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
319 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
