Question about Consew 226R-1
The timing is out on my consew 226R-1, how do I fix it?
The upper thread will not pick up the bobbin thread
    New Friend:
  • 6 Answers
Safety clutch may be disengaged. Push and hold down the right hand button on bed of machine and turn handwheel away from you until it comes to a stop. Still holding the button down, force the handwheel away from you until you hear a loud click. Release button and now see if you can pick up needle thread.
Posted on Jan 08, 2013
kevin000
  • 1847 Answers
SOURCE: consew 226 r sewing machine
Take the bobbin out and check for dirt or broken thread in the hole.
Posted on Sep 15, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
  • 76 Answers
SOURCE: My consew 226R-1 is out of time, can anyone help??
http://consew.marginspluslive.com/images/products/PARTSBO/224-224r1-225-226r1instr.pdf
THIS SITE HAS A MENUAL YOU CAN PRINT
I HOPE THIS IS HELPFUL
MONI
Posted on Sep 27, 2009
SOURCE: Need instruction manual for Consew 226R-1
Found manual on internet from company
Posted on Jan 04, 2010
  • 6 Answers
SOURCE: I have a consew machine 226 and the needle thread
your needle is in backward, the groove must point to the left.
Posted on Jan 27, 2010
I have a consew 225 I think and when I try to bring the thread up from the bobbin the thread from the needle goes down and around the bobbin to bring up the bobbin thread and catches. It will not pass
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
Jul 18, 2012 | Consew 226R-1
I believe the timing is off-how do I time it?
try these sites
youtube
fixsewingmachines.com
sewusa.com
Apr 10, 2012 | Consew 226R-1
I was sewing all was going fine and suddenly it wont pick up the bobbin thread everything seems to be moving what do i do i tried to reset clutch but when i push the button it wont move back ???? help...
perhaps you had a little jam of fabric or thread and threw off the timing of the hook that helps pull up the bobbin thread. the manual shows you how to loosen the screws and move the hook back. Might take a couple of times and be sure to tighten the 3 set screws well when you get it right. They are under the machine, so you have to loosen the belt and lay it on it's side.
Can't remember where I downloaded the manual last year, but on page 13 it shows the instructions. The photos are bad, so watch carefully. Try consew.com and download 206rb-5 manual. looked the same to me.
Not easy to do, use a flashlight and follow exactly and it will work. I did it the first time and I am not a guy and not a mechanic.
HS
Nov 05, 2010 | Consew 226R-1
My husband purchased an old model Consew machine. It is mounted on a table and came with the instruction manual for models 225 & 226R-1. The machine will NOT pick up the bobbin thread. Any ideas?
Check your manual to see which way the flat side of the needle shank should face. With modern machines, it's usually to the rear, away from you, but with older machines there was more variation.
The most common reason the needle won't pick up the bobbin thread is because the flat side of the needle is facing the wrong way for that machine.
Hope this helps!
Robbie
Aug 07, 2010 | Consew 226R-1
The book on my consew 226r-2 says to adjust the screw to tighten or loosen tension on the bobbin, I can't see a screw, where is it?
It is usually a little tiny screw on what holds the bobbin in and where the thread passes through the bobbin. (The holder...not the metal or plastic bobbin spool of thread...it's sometimes called a shuttle to avoid confussion.) When you tighten or loosen the screw on the bobbin holder it puts more or less pressure on that metal hook the bobbin thread passes through.
Feb 04, 2010 | Consew 226R-1
Consew industial machine keeps skipping large areas
remove the front cover around the needle area also you may have to just strip the machine down!! to the hard ware with the bobbin door removed rotate by hand the crank till the neddle goes down to the bobbin area and losen the screws on the bell part of the crank and adjust it till
the needle is dead center and all the way into the bobbin then tighten and reassemble
Jan 14, 2010 | Consew 226R-1
I have a consew machine 226 and the needle thread will not pick up the bobbin thread .
Dec 30, 2009 | Consew 226R-1
Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Nov 05, 2008 | Consew 226R-1
Thread braking
Check the condition of the top pressure discs and the bobbin case tension. Check for wear in the hook - is the bobbin case seated correctly? Check the tension spring in the bobbin case. I doubt timing has anything to do with the problem. Unless the hook's picking up the top thread a little late, thereby "spearing" the thread. The hook could be catching the thread loop too late. Sounds to me like there's a parts or a small adjustment problem. You don't mention thread or needle size. That's another area of concern at times.
May 22, 2008 | Consew 226R-1
Consew 226R-1 Logo
109 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
