Question about Samsung WA5451ANW 4.7 Cu. Ft. White Top-Load ENERGY STAR Washer
I'm getting a tE1 error code (thermostat error), how do I fix it?
How do I fix this Parse error: syntax error, unexpected '.', expecting ')' in /home1/ragtop23/public_html/wp-content/themes/twentyten/comments.php on line 78?
Change to another theme.
Delete the twentyten theme
download and install twentyten again. Done...
next time save a backup of the file before you start editing it.
Dec 20, 2014 | wordpress.org
TE1 error...thermistor seems fine
that's a bad thermistor,the thermistor isn't alot of money it's like 15 dollars,change it out,remove the code anf go from there but it should fix it,also check the wire connections.the tech sheet will tell you how to get it into diagnostics to remove the code
Nov 24, 2013 | LG DLE5977 Electric Dryer
How can I fix an error code 'c01-563' on Riso RZ370
Changing the ink tube or the RFID chip on the ink tube may solve your problem.
PrntNow.com
Apr 12, 2013 | Office Equipment & Supplies
Power went out last night. I am now getting a flashing H2 code. What should I do?
reset error using simulation mode 14 & 16. this is occur due to fusing thermistor is open. still occur remove fusing unit & clean thermistor using alcohol & reset thermostat. then fix it & again reset error using simulation mode 14 & 16.
still h2 appear replace old one to new 1.
May 24, 2011 | Sharp AR-M205 Copier
HELLO MY DRYER LG MOD DLG5988S GIVE ME A CODE TE1 AND IT DONT START ONLY MAKE A BIP SOUND. SOME BODY CAN HELP ME??
The "tE1" error has to do with the dryer's thermistor. The code indicates the thermistor is open, meaning that it has cracked or broken off, possible the wires are off. if the wires are good then you will need to replace the thermistor. The Thermistor is located next to the blower section of the dryer should have a bule and orange wire and it is on the blower housing. here is a picture and if you need to order it:
http://www.repairclinic.com/LG-Dryer-Sensor-Or-Thermistor-Parts
Mar 19, 2011 | LG DLG5988 Gas Dryer
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be...
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Jan 23, 2011 | Ovens
Timing on a 1985 toyota 22re
Before you set engine timing i recomend that you check for trouble codes. You can do this by jumping TE1 and E1 whitch on your engine is a round 2 wire plug on the drivers side, by air box. if you have a code then have the problem fixed, because some codes will effect engine timing. You must have the TE1 and E1 jumped when timing engine. The engine timing marks are on the oil pump on the front of the engine,down by the crankshaft. Timing is set to 5 degrees advanced(factory). Also make sure you have no vacum leaks they will also effect engine idle 900rpm which is the setting for setting the timing at.
Picture of TE1 and E1
Also make sure your engine distributer cap is good and same for plugs and wires. I hoped this helped.
Also timing chain strech which will affect timing.
Aug 08, 2008 | 1986 Toyota Xtracab
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Jun 11, 2008 | LG DLE5977 Electric Dryer
Samsung WA5451ANW 4.7 Cu. Ft. White Top-Load ENERGY STAR Washer Logo
88 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
