Question about Gap Digital Sport Watch
Set week day alarm on gap sport watch
I have the time set, I have the alarm set. I can't fgure out how to change the date and I can't figure out how to set what days of the week for the alarm to go on. Help! Please!
How to change date on shhors digital watch
Use the S button on the lower right to cycle through the minute, hour, date, month, and day of the week, and use the D button on the upper right to change those things. Push the M button one more time to get back to normal operation. To set the alarm: Setting the alarm is the same as setting the watch.
Amazon.com: Customer Reviews: SHHORS Sports Water Resistant ...
https://www.amazon.com/SHHORS-Sports-Water-Resistant.../B00WDPZWYY
shhors digital watch instructions - Google Search
Apr 08, 2017 | Watches
How do I set alarm on Armstrong 45/7041 watch? Did not come with instructions
A= reset
B= Mode
C= ST/STP
D= Light  (edl)
•SETTING TIME AND CALENDAR
1.For time telling mode, press 'B' three times. The seconds should start to flash. Press 'C' to zero out the seconds.
2. Press 'A' minutes will flash, press 'C' to set the minutes.(holding down C will advance the digits faster)
3. Press 'A' hours will flash, press 'C' to set hour.
4.Press 'A' date will flash, press 'C' to set the date.
5.Press 'A' month will flash, press 'C' to set month.
6.press 'A' The day of the week flashes, press 'C' to set day of the week.
7.Press 'B' to finish and it will return to the time.
IF ANYMORE QUESTIONS ABOUT SET FEATURES SUCH AS 'STOPWATCH, SPLIT TIME, SETTING 24 HOUR ALARM, ACTIVATING ALARM, OR SNOOZING THE ALARM'. FEEL FREE TO CONTACT ME @ vannabeltran8.sb@gmail.com WITH 'ARMITRON WATCH' IN SUBJECT BAR AND I WILL SEND YOU PICS OF THE MANUAL.
-Savannah:)
Feb 14, 2015 | Armitron 457004WHT Womens White Nylon...
How do you set the time/date, etc.? This watch is a 1440 sports with plastic wrist band.
press and hold mode button until the digits flash (it is to set the alarm) then press again once the mode button, this time the time flash to be set, the digit that flash is changeable, the lower right button is for adjusting, the upper right button is to choose what you are going to change, while pressing the upper right button you will see all you have to change the time , the date, the day of the week. if your done with all of this. press mode button once, i hope i had been helped you.
Sep 06, 2011 | Timex 1440 Nylon watch
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
How to turn off hourly alarm on Gap Sport watch?
Click reset button (lower right) - this shows you the alarm time as indicated by a large letter 'A' that appears in the display.
Keep holding the reset button and simultaneously press the mode (lower left) button.
This toggles the days of the week at the top of the display.
All days shaded in black means the hourly alarm is on.
All days clear means the hourly alarms is off.
Now, if I could just figure out how to choose the exact days the alarm can be set to ring ... it seems like it is possible.
Aug 16, 2009 | Watches
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Gap Digital Sport Watch Logo
42 people viewed this question
Top Gap Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Gap Watch Expert? Answer questions, earn points and help others
