Question about HP Pavilion A250n (DF253A#ABA) PC Desktop
Hp a250n just runs at high speed never starts windows or the monitor
  • rmw2628296
    rmw2628296 Jan 12, 2013
    The problem the was the ddr ram it will run on two 512 mbs this computer has 4 slots for memory it now appears that the two expansion slots will not allow the computer to start
  • Brian Sullivan
    Brian Sullivan Jan 12, 2013
    well done narrowed it down to ram sockets check for dirt or any debri clean with air do not use solvents might be the actual memory slothttp://www.youtube.com/watch?v=wGp5AiyJI... repair memory slot
  • HP Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 08, 2013
2 Suggested Answers
oblivion2k
  • 150 Answers
SOURCE: my HP a250n boots up to the windows logo, then
Sounds like your windows installation was corrupted. Try booting into safe mode from BIOS. If that doesn't work you will need to re-install Windows.
Please rate, Thanks!
Posted on Mar 31, 2009
Ml150 g3 high speed fan , i can not turn it off
Can u confirm that is it giving some error massage in startup screen and install smart array and check that windows is coming or not, If windows not running then installed OS in your server
Feb 28, 2013 | HP ML150 G3 Rack Conversion Kit (1249012)...
A250n hp will not read the ram expansion slots that extends the memory what is possibly wrong with it
Check you are fitting the same specification of RAM into the expansion slots as you have in the others. To make doubly sure fit the same make and size, this will swerve any compatibility problems.
Jan 12, 2013 | HP Pavilion A250n (DF253A#ABA) PC Desktop
My hp L1506 going to sleep again and again
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control Panel.
2)Click "System and Maintenance," and then select "Power Options."
3)Select "High Performance" to disable the overall sleep mode. The monitor will still go into sleep mode unless you click "Change Plan Settings" and disable all sleep options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans," and then click "Change Plan Settings." Change all of the options to say "Never."
Dec 16, 2010 | HP L1506 15" LCD Monitor
I have a a1630n and suddenly when I turn it on, the fans run fast and screen stays black. No beep. let it sit over night and on the first boot up the screen will go to the windows xp logo and than go...
Alot of problems with the HP.
First thing is make sure when you changed the battery you would need to check the jumper that allows you reset the BIOS and let you use the computer.
The other is the fan speeds it normally should go a little high not so high but in your case the CMOS battery that was installed could cause some things not to work especially if it supports PCI-E. The motherboard in your system must have a dual video connector. One is on the board and one is on the PCI-E. Make sure the monitor is plugged into the right port. It should work after that. If not remove the PCI-E card and see if it works with the onboard connector.
Nov 21, 2010 | HP Pavilion a1630n PC Desktop
Front panel connection diagram
Well, I just prepared the diagram for you, I hope you know at least to make the connections..
If you have problem, let me know.
Your rates and testimony will be highly appreciated.
Good luck
Thanks for using FixYa.
Jul 01, 2010 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Occasionally boots up
restart and repeatedly tap F1, loads to BIOS, press F5, press Enter, press F10 and press Enter, allow to restart.
If problem recurs, run a test on the hard drive to check for errors,
Apr 11, 2010 | HP Pavilion A250n (DF253A#ABA) PC Desktop
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
My screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Jun 14, 2009 | HP Computers & Internet
My HP a250n boots up to the windows logo, then the screen goes black and stays that way. Hdd continues to spin.
Mar 31, 2009 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Hp pavilion a250n no video output
no
open your cpu cabinet.
then refix ram and nvidia card into its position after clean dust from it.
when u refix proprerly your problem is resolved.
Oct 03, 2008 | HP Pavilion A250n (DF253A#ABA) PC Desktop
HP Pavilion A250n (DF253A#ABA) PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
