Question about Refrigerators
Freezer inner liner bulge
Inner liner of freezer bulges
  • 1314 Answers
SOURCE: Refrigerator
yes i have its from over foaming used to happen a lot in the old days are the poppins sounds when the compressor firsts cuts on if it is its from freon expansion and you can get a sound damping pad and put around the line's comming in to the evaporator
Posted on Jan 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: bulging capacitor
Mitsubishi just got some bad capacitors and they end up running hot which cause them to bulge. If you are planning on doing the repair yourself I would suggest getting the service manual at the following link, as they will email it to you and they will also provide free tech support with an expert on that chassis and he will help you with the repair as special capacitors have to be installed and while your inside the set you should change any of the caps that are prone to failure. they know which ones they are and they can make the repair an easy one for you. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 31, 2008
HondaAl
  • 72 Answers
SOURCE: bottom radiator hose cold. upper radiator bulging.
The fan won't come on because the thermoswitch is in the bottom of the radiator, without coolant flow the switch never gets hot. Just because a part is new doesn't mean it is good, is the thermostat an aftermarket part ? I would take out the thermostat (leave the gasket) and see if the bottom hose gets warm. If the bottom hose does not get warm, you may have a blockage or bad water pump
Posted on Apr 18, 2009
bobint17
  • 270 Answers
SOURCE: Battery door will not close anymore because battery is bulging
change the battery with a new one.
Posted on Jul 17, 2009
  • 67 Answers
SOURCE: No picture, no sound, no bulging caps
need more info on tv ex plasma proj model yr manufact then i my be able to give u some accurate advice
Posted on Jul 25, 2009
I have a fish pond and our new puppy has pushed some of the rocks surrounding the pond into the pond and has torn the liner. What is the best way to repair this.
drain fish pond see what kind material the liner is made of and trouble shoot get a bulge pump pump the water into something that can hold it maybe like a kiddies swimming pool or something like a bigger yard swimming pool for fish and water wlmart sells swimming pools
Feb 20, 2013 | Fish
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
When we were watching tv it made a crackling noise and went blank
the inner fuse in the power supply region must have opened or the filter capacitor could have bulged
Sep 25, 2011 | Bush Industries IDLCD26TV16HD LCD TV
On philips 26pfl5322 Sound ok. screen white at switch on, after half hour pic. perfect for rest of day. tried freezer and heat no joy
Good day!!!!
please try to check if you have bulged on the top capacitors on the power supply board...
if you have bulged capacitors please replaced it only with the same type,ratings and value...
Thanks for using fixya...
Aug 09, 2011 | Philips 26PFL5322 26 in. LCD TV/HD Combo
Freezer works but refrigerator does not
First, open the freezer and look for a snowy frost build-up. See if it's bad enough to cause bulging in the inner panel at the back. If so, you may have a defrost problem. Also, make sure nothing is blocking the ariflow between the freezer and fresh food sections.
Listen to see if the compressor is running. If it is, open the refrigerator side and turn the freezer control off, then back on, three times within six seconds. Did the compressor stop running? If not, the problem is very likely the adaptive defrost control board. Replace it.
If it does stop after "forcing a defrost cycle", you probably have a burnt-out defrost heater. It will need to be replaced.
Dec 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
My tyre are overair and it expanded?who can i fix it?this happen a week ago.i try to make it back to it shape and low it presure but it still expand..
I think that your tyres are faulty as the volcanisation of the tyre is uneven. It will be good to show your tyre to the manufacturere or if the bike is new to the dealer for a replacement.
Once the tyre has bulged then it is softened on this section as it is uneven and can be dangeorus.
You can use within the bulge area an inner casing but this will make the tyre unbalance and the riding will be diffficult. So dont attempt this method.
So please check this out and hope my advice helps. Good day
Aug 17, 2010 | 1996 Yamaha XJR 400
Refrigerator has a bulge on the outside of the cabinet on left side where the ice maked is located and that side of the box is cold and sweating
Empty the ice from the ice maker. It sounds like you have a build-up of ice between the ice maker and freezer wall. When you thaw this ice, the bulge should go away. You may need to temporarily move the ice maker for a few hours while the freezer thaws.
Feb 05, 2010 | LG Refrigerators
Upper Rad Hose bulging when engine hot
Unrelated to what you did. Replace the upper hose before it breaks.
Jun 21, 2009 | 1996 Ford Windstar
Refrigerator
Jan 24, 2008 | Kenmore 72073 Top Freezer Refrigerator
Bi-metal thermostat
If its bulged out ----its bad,  and it shows the bimetal on the schematic
Oct 12, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
