I had trouble with with my Maytag front load washer not wanting to drain out. It was also noisy. I fixed it myself . Here was the problem. The drain filter had nails, coins and a huge ball of lint
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
It looks like the cycle is being interrupted. Perhaps you dislodged a sensor in the drain area when you were cleaning out the drain. It could also be, the drain sensor is now in the wrong position.
Posted on Jan 10, 2013
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 262 Answers
SOURCE: kenmore 41742042100 front load washer
IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
Posted on Jan 02, 2008
  • 177 Answers
SOURCE: LInt filter
Find you owners manual, it should say how to clean the button trap on your pump
Unplug the machine FIRST!
Get some towels, you will have water coming out.
if the tub is full of water you will need to bale it out!
Remove the lower front panel, usually two screws,
look for the pump it will have hoses on it. now lay some towels around, expect water.
Unscrew the end of the pump, if it has a button trap or lint filter.
it will be on or near the pump refer to your owners manual
If you dont have an owners manual you may find it at Samsung.com?
Posted on May 03, 2008
ginko
  • 19396 Answers
SOURCE: washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Posted on Oct 12, 2008
  • 1294 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
My Maytag mah5500b front load washer makes a loud knocking sound when spinning. It sounds like a problem with the drum. Can I fix this myself?
Could be the bearings or the "spider", the mechanism that holds the drum and is attached to the bearings at the back of the drum. If one of the arms snaps or the bearings go then it sounds really noisy. These are replaceable, but can be expensive and difficult to replace. It may be worth weighing up the repair cost with possibly only a 3 month warranty on the work versus a replacement machine and its' warranty.
Sep 01, 2015 | Maytag Neptune Washing Machines
How to replace the drain boot on a maytag front load washer
I have taken many apart over the years, and I still refer to YouTube for advise.... Fixing a No-Drain Problem in a Front Load Washer http://youtu.be/b3kL3daLZ9g
Feb 24, 2015 | Maytag Neptune MAH5500B Front Load Washer
Noisy front load maytag washer
Center bearing going bad,Maytags have a history of this and the whole tub will have to be replaced cause the bearing is made no to come out and.it's best to get a extended warranty on all Maytags,the repairman is so busy now days.
Feb 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
Suds error maytag neptune
check for water left in units tub,if so check pump inlet and outlet and drain pipe in the house for foreign objects,then if clear make sure pump drain is running if it is,but noisy it may be bad,as in the impeller on the motor shaft may be loose and the water may stall the pump
Oct 22, 2012 | Maytag MAH2400A Front Load Washer
Spinning very noisy.
Hi avenick05,
The noise you are hearing might be the Drain pump catching on a foreign object.
Please look at my Tip below on how to clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Jul 27, 2011 | Maytag MAH55FLB Front Load Washer
I have a maytag fav6800aww and it doesnt want to drain the water and it makes a loud noise coming from the pump. i already replaced the pump and it still has the same symptoms. what should i do to fix this...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
WATER IS NOT DRAINING. CHECKED HOSE, PUMP, BELT, ETC. WANT TO SEE IF PLUGGED WITH CLOTHES AROUND DRUM BUT AM HAVING TROUBLE GETTING LID OFF. PUSHED IN LOCKS WITH PUTTY KNIFE AND STILL LID WILL NOT LIFT.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | Maytag MGT3800T Top Load Stacked Washer /...
Maytag model MAV208DAWW washer, clothes still damp to wet after spin cycle. DIYer, want to try to fix it myself.
excellent love a guy willing to try
ok wet cloths
with this model i would the first thing to check is the height of your drain,,,, if the drain ios highter than 6 feet the unit just cant do it
next check your belt, this sometimes becomes stretched, more than 1/2 deflection id change it
Oct 25, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
