Is my Sanyo LCD-20XR1 digital or analog - Televison & Video
3 Suggested Answers
  • 17 Answers
SOURCE: Digital or Analog>
I believe this tv has a built in digital tuner. To verify this, using your remote attempt to change the channel to say 3-1 or 3.1 if you have a digital tuner this is how a digital channel will show up. Also if you go into your menu under channel scan you should see a choice named dtv. And finally on the back you will have a coax connecter named dtv. The latter is not always true. If it does turn out to be standard format tv, you can still purchase a digital set-top box that will decode digital for you. Keep in mind that you must have a good uhf off air signal in your area to recieve digital signals. Good luck.
Posted on Feb 20, 2008
  • 73 Answers
SOURCE: Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Posted on Jan 05, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
Feb 04, 2015 | Sanyo DP26640ARB - 26 LCD HD TV 720p...
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
How can I tell how old my Sanyo TV is. I bought it used.
antenna to converter converter to tv tv on ch3 (analog)
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
and
Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Analog or digital?
Your tv is digital on the procession stage, it can receive analogue or digital signals. the convertion is in side a tv
Dec 15, 2008 | Sanyo DS13204 TV
Sanyo DS32224
Maybe buy a new one? Maybe LCD? Maybe keep up with technology? Feb 09 they will no longer have Analog Tuner so you need to get a New one anyways , it will all be digital according to the government!
Jan 12, 2008 | Sanyo DS32224 TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
