Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water dispenser dripping
I have a Frigidaire PLHS267ZAB6 side by side with ice and water dispenser in the door. It is 5 yrs old and the dispenser water started dripping and will not stop
  • Anonymous Feb 16, 2009
    Where is the "seat in the door valve" located?
  • mfagan May 12, 2009
    water dripping from water dispeser
    and where is the part your going to mention and how do i get to it
    President:
  • 1,214 Answers
The seat in the door valve has probably failed or has some trash in it.
Posted on Jan 20, 2009
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
It's not making ice. Not sending water to the ice maker. I replaced the filter this morning. Water is dispensed for drinking , but not for the ice maker.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Aug 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I HAVE A FRIGIDAIRE FRS26HF7BW1. NO WATER GOING TO ICE MAKER. UNIT APP. 6 YRS OLD. FIRST PROBLEM I HAVE HAD. WHAT'S WRONG. WATER TO DOOR IS FINE.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips
Sep 27, 2009 | Refrigerators
Side by side Frigidaire. The water dispenser
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the tube.. You can take the water line off the valve and watch to see if it drips.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 30, 2009 | Refrigerators
I have a side by side fridgeits about 10 yrs old
Aug 26, 2009 | Refrigerators
I have a side by side fridge/ freezer bought new 5 yrs age and the water/ice dispenser keeps leaking water. I noticed the the lever in the dispenser area seems loose. what would cause this type of problem?
One of two thing. Either the flap is not closing all the way allowing condensation to build up and drip, or you have a seaping water valve allowing water to seep out of the water spout insde the door.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Whirlpool Refrigerators
Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Jan 17, 2009 | Frigidaire FRS3R5EMB Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
595 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
