Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
MFC-440CN printer. Colors are not proper
Black is coming out blue and red is coming out very light pink. I uninstalled the printer and reinstalled it. Did not help
  • 124 Answers
I'd like to help if I can. These printers have 4 cartridges. One black, one magenta (reddish), one cyan (blue) and one (yellow). The text and pictures are printed with a combination of these inks. When one or more is low, printing will be as you described. Your situation seems to be that you are out of black (so the cyan is trying to help and can only print blue) and you are probably out of yellow so the magenta is trying to do what it can. If you'll change all of the cartridges, I am pretty sure that you will have your problem solved.
Finally, there is a great place to get cartridges for your printer. The link is:
You can buy a multi-pak consisting of 4 black and 2 each of the three colors for $39.95 plus s/h
I use the cartridges and they have proven to be reliable.
If my help has been satisfactory, please give me your rating.
Posted on Jan 28, 2009
  • Bernie Thames
    Bernie Thames Jan 30, 2009
    Do you still need help? If not, and my information was acceptable, I'd appreciate your feedback. Thanks!
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
I am tired of this mfc 440cn not printing in black only mode if the colors are empty, even one. I want to print and work with the black only cartridge. How can I get it to print in that mode only. ie: ...
Yes! There is a way around the problem. On each ink cartridge there is a narrow section that a sensor in the printer reads to decide when the ink is low. Cover that spot with a piece of black electrical tape to fool the sensor and you can keep printing. This page has good pictures showing what to do.
Sep 11, 2011 | Brother MultiFunction Center MFC-440CN...
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
Brother mfc-440cn not recognizing black cartridge
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 28, 2011 | Brother MultiFunction Center MFC-440CN...
All colors print only black does not print. New
reset your print option set automatic or color select
Aug 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother MultiFunction Center MFC-440CN...
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Replaced ink cartridge printer continues to say no cartridge
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Nov 08, 2008 | Brother MFC-440CN InkJet Printer
Brother mfc-440cn scanner/copier bulb dim
its cheaper to buy a new one.
You might find an 2nd hand mfc with a defective printhead. you can use this as a spare part.
Jun 23, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
110 people viewed this question
James Cagle
James Cagle
Jim Keysor
