Question about Zyxel (91-004-361002) Wireless Router
Setting up a new modem - Zyxel (91-004-361002) Wireless Router
  • 826 Answers
After you press the reset. Your laptop has to be physically connected to the router to configure it
Open your web browser, type in "192.168.1.1" and login using username and password.
In "Basic setup" DHCP Server should be "Enabled"
Enter "Domain name" Name your private network
Set the starting IP address - Enter 10 ( any low number)
Set time zone
Save Settings ( button at bottom of page )
Under Advance Routing, set Operating mode as "Router"
Save Settings
WIRELESS TAB
Wireless - set to MIXED
Wireless network name - same as domain name
Select a wireless channel (default is 6)
Wireless SSID Broadcast - ENABLE
Save Settings
Wireless Security tab
Select WEP
Default transmit Key - select 1
Enter a pass phrase to generate a security code, click on Generate
WRITE DOWN THE PASSKEY ( aka, Security code)
KEY 1 should have this PASSKEY entered.
SAVE SETTINGS
On your laptop, right click on the icon for the wireless on the task bar, select "View available networks"
Select your network, it should prompt you for the passkey, you will need to enter it twice
Posted on Jan 08, 2013
I changed my internet modem and am not using the router I had been using. I have attempted to access Netflix and get error unable to connect to the internet.
Judit,
We need ore information. Does the new modem you are now using have a built in "router"? If not, you had better reinstall your old router as when you just use a plain old modem from either cable or dsl your computer will be visible to the "low life hackers" out in the internet and it will be so easy to gain access to your computer and files it will and should scare you! Are you now using a router with your new modem? IF NOT, reinstall your old router with your new modem! The reason your not getting Netflix could be that the port settings on your old router will not be the same as the modem and if your new modem does have a built in router, you will need to "reconfigure" your Netflix with the new modem/router. The ports that your old router allowed access to Netflix will not be the same in the new router. You need to set this up yourself. Good luck.
Mar 22, 2015 | Miscellaneous
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
My router won't work with my Qwest modem.
Are you trying to set up the router.
You can do it manually without the CD.
When you connect the computer to the quest modem, does it work?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | D-Link Computers & Internet
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
We had to replace our modem & our wireless router isn't working
You have got a new modem. You will need to change the settings of the router according to the new modem.
First make sure that your computer is able to go online when connected directly to the modem. If that works then connect the computer to the router and the modem to the router.
open the set up page of the router and set up the router.
Click here for more info
Nov 28, 2009 | Dynex Wireless-G Broadband Router
Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
Nov 05, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
New modem will not work with my Belkin F5D7230-4 router
I would start by re-setting the modem. Disconnect the power for the router and modem. Wait a minute or two. Plug the modem back in first. Wait for the modem to complete communication with your internet service provider. When all communication lights are good on the modem then plug the power into the router. It amy take a few minutes to get all the lights. Hopefully this will allow the DHCP to release from the old router and renew to the new one. Make sure if your internet provider requires any manual configurations that they are properly configured in the new router.
Sep 12, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I have an old modem from a previous internet provider. is it possible for me to use the same modem on my new internet provider? i've tried pressing the reset button at the back of the modem but...
more often than not, ISP's have their own settings saved inside the modem. so if you're going to change ISPs, the settings on your old modem might not work with your new ISP. settings like authentication and username and passwords, they differ among ISPs because they have their own system for authentication, etc. it is recommended that you get a new modem with your new isp.
Apr 21, 2009 | Computers & Internet
Modems/operating system
yes the modem is independant of what computer it's on ....... unless in the modem it's self you have set up some of the security features like Mac filtering etc then it would have to be added, but as far as it working with your new computer it should be just fine if it's not let me know and i will assist you in connecting it.
The modem is most likely set up as dhcp so when you connect your new computer it will give it the required setting to connect.
Oct 08, 2008 | Computers & Internet
I have a problem with my connection
which modem are you using and is it a built in modem, you set the configuration of the modem and then set up new connection
Feb 07, 2008 | Intel (FAXINTEL) (fax-) Modem
Zyxel (91-004-361002) Wireless Router Logo
99 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
