Question about JVC AV-36950 TV
JVC AV-36950 TV won't turn on
I think this is similar to others I've seen posted. When trying to turn the set on either remotely or from the front panel push button, set tries to turn on, red LED lights quickly and then shuts off. Sometimes it tries to turn itself on again.
Is this also a power supply problem? What is the theory behind this supply/components that might aid me in troubleshooting?
  • 684 Answers
In this case wat u can do is try to Turn On the set without the memroy card inserted....
If still same Problem u can try replacing the batteries.......
If the set turns on without the Memory card replace the memory card....
Good Luck.....
Posted on Jan 20, 2009
JVC AV-36950 that turn off after being on 30 min
Check for any loose solder contacts at its main power regulator [SMPS] stage. Re-solder all the suspected solder terminals. If you wish to get some details; visit the site linked here. Pull up older posts.
Oct 12, 2017 | JVC AV-36950 TV
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
Will not turn on
Go to the following blog site for detailed instructions on how to fix the TV yourself for around 2 dollars! I fixed mine myself this weekend and I know nothing about TV's. Thanks to this site, I saved hundreds of dollars.
Good Luck...............Kim
Oct 13, 2009 | JVC AV-36950 TV
JVC Av 36950 is dead
I just looked again on another site--this is the set that has the cap that goes bad--do you know what a filter cap looks like? it will be black and round with 1000 mfd 25vdc marked on it--near a big diode and next to a square black relay--when the site is back on Tuesday I will give you a location number for it(printed on top of the circuit board) it should be flat on top if you open the set and see it with the top not flat-buldged up--that is the bad part--fixed dozens of these with this problem--if you find it bad go to a higher rated voltage cap---50 volt at least--you have my email--part has only 2 leads and with the back off and located is a 5 minute job to fix.....give me a email if you have any questions or need help.(I can email you a photo of what a cap like this looks like)
SD TECH
Sep 06, 2009 | JVC AV-36950 TV
The power button keeps clicking off and on
My set did the same thing. I found the attached blog while I was looking for answers on this website and it explained how to fix the set myself at home for around 2 bucks!!! I tried it and it worked!
Good Luck...Kim
Aug 30, 2009 | JVC AV-36950 TV
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
Jan 07, 2009 | JVC AV-36950 TV
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
Dec 09, 2008 | JVC AV-36950 TV
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
JVC AV-36950 TV Logo
728 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
