Question about Dewalt Round Head Framing Nailer D51845
D51822 Dewalt framing clipped-head nailer manual
rowdy45176
  • 2176 Answers
SOURCE: Is there any way to
I am assuming that a nail got jammed? If so unplug air to tool, remove the rest of nails and turn it over. try to find a flat piece of steel smaller than the nose where nail goes and gently tap the driver back up and remove jammed nail. If the driver is broken that is a different fix. Hope this helps
Posted on Dec 09, 2008
  • 16 Answers
SOURCE: DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Posted on Jun 15, 2009
  • 1388 Answers
SOURCE: DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Posted on Jun 18, 2009
brewerstool
  • 141 Answers
SOURCE: Head Framing Nailer - D51822 - dissasembly problem
You have to remove the cylinder. To do this use two flathead screwdrivers on opposite sides and gently pry the cylinder out being carefully not to damage anything. If you have to replace the oring on the bulkhead it takes a little bit of finesse to work it out of the head. I usually put the nailer in a vise and use both hands, two fingers from each to pull the bulkhead out. It's not easy and you will bust your knuckles.
Posted on Sep 08, 2009
  • 142 Answers
SOURCE: Where can I find the parts I need
need to check with Harbor Freight about parts
they are the distributors for that brand gun
Posted on Nov 22, 2009
Dewalt framing nailer D51822 type 1
you may have to hand push the anvil back up , using too much air pressure will ever time cause this
Jun 13, 2016 | Dewalt Heavy - Duty 31° Clipped Head...
Framing nailer will not fire
Inside the cap the o-rings upper seal on cilinder replace it looks like not more available and many more parts are sold out.
Sep 09, 2014 | Dewalt D51822 Clipped Head 2Inch to...
21 degree round head framing gun wont do nothing when air hooked up
If it hit the slab it may be toast. Out of round cylinder body or head problems
Sep 04, 2012 | Dewalt D51822 Clipped Head 2Inch to...
DeWalt D51822 Framing Nailer: Replaced the trigger valve and air is still coming from the nose of the gun. I would think no air should get past the trigger valve until pressed. What's wrong?
Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer. Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. Good luck with your repair
Jul 05, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
Common problems dewalt clipped head framing nailer
there is NO easy solution for this, but unplug air and get a pair of safety glasses and a punch and try and knock the driver up into the tool away from the nail or if it is just jammed try and pull the nail out. You didn't really specify where the problem is. Let me know if you need more assistance.
Jan 05, 2012 | Dewalt D51822 Clipped Head 2Inch to...
D51822, how do you know if it is type 1, 2, 3, or 4?
it should state that on the nameplate. that is the only place that I am aware of.
Aug 15, 2010 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt D51822 leaks air
its a seal leak, but if it's under warrenty, send it back
it's not worth voiding the warranty by doing it yourself
Dec 09, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Sep 08, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt Round Head Framing Nailer D51845 Logo
19 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
