Question about Honda EU6500iS Inverter Generator
Honda eu6500is doesnt run smooth with eco throttle on, low RPM but runs fine with eco throttle off? got any ideas
Just bought this used, wouldnt start. cleaned carb, started fine, but wont smooth out and idle with eco on. with eco off RPM increases and engine runs smooth, Have taken carb off 3 times and looked for a problem, soaked it cleaned it and still have problem.
  • 82 Answers
SOURCE: 1989 honda prelude enigne idles high then low irratic
I had the same problem on a Rover. There was a leak in inlet manifold that was caussing the problem.
To verify, spray some sealant to temporarily seal the inlet manifold .and the eratic idling should disappear for some time.
If it does, you know there is leak in inlet manifold which you can take of and refit with a new gasket.
Posted on Oct 27, 2008
  • 10 Answers
SOURCE: I have a 85 Honda Shadow vt 500. Engine is surging
did you clean all the jets good sounds like it may be in the jets and needle part of the carbs
Posted on May 07, 2009
  • 3 Answers
SOURCE: 2004 Honda Civic -Code P0122 Throttle Position Sensor Voltage Low
yes, this is the case of a failed throttle body, in which case it needs replaced, the car is getting too much fuel causing the high idle. this needs replaced asap. you could proably find a small independant honda shop that could do the work for less.
Posted on May 12, 2009
chadschloss
  • 11 Answers
SOURCE: magna engine surges
The carbs may need to be cleaned. Try running seafoam in the tank first and see if that clears some of it up. The slow jets may be plugged up inside the carbs. If the snorkel had been removed from the airbox, it could cause siminlar problems as well. have you changed the spark plugs yet? be sure to check out the Honda Magna forums for more info:
http://forums.delphiforums.com/MagnaRiders
http://www.magnaownersoftexas.com/forums/
http://v4hondabbs.com/
Posted on Sep 08, 2009
mwoodring1
  • 496 Answers
SOURCE: 2001 Honda Shadow ACE 750 idles, but won't rev up
vac leak craked boots
Posted on Jan 05, 2010
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
What controlls the rpm on a eu6500is
The inverter signals the throttle motor, which is really just a small servo motor on the top of the carb. When the inverter senses more load, it increases the throttle to compensate.
Jul 10, 2015 | Honda EU6500iS Inverter Generator
EU6500 eco switch on won't idle down the engine
need more info did you leave gas in the tank without stabil if so carburator is got gas sludge in it
Feb 27, 2014 | Honda EU6500iS Inverter Generator
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
Hi i have a cb1300 on 04 plate bought recently . in low gears and approx 2000 to 3500 revs the bike seams very snatchy and surging on steady throttle but change up a few gears and its fine . its not like a...
Check your clutch plates, it may be slipping at higher RPM on low gearing but have enough contact area on lower RPm higher gearings. Good enough to rate this advise?
Sep 01, 2010 | 2004 Honda CB 1300
Under 2000 rpms runs bad/hesitates/check engine light
This IAC valve runs only when your foot is off the gas pedal. Mainly to keep the engine from stalling and keeping it at a safe RPM. If it is running bad under 2000RPM, more than likely its the IAC valve or a vacuum leak. Clean or replace the IAC valve....Hopefully this helps!!
Apr 17, 2010 | 2000 Honda Civic
98 galant 2.4 engine speed uncontrollable after 1600 rpm
check automatic idle speed motor if equipped.
Jul 07, 2009 | 1998 Mitsubishi Galant
Honda EU6500iS Inverter Generator Logo
111 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
