Question about Carrier Heating & Cooling
Carrier Split AC showing e2 error. Voltage is showing 28v between R & C, trips and turns back on in 15 sec.
  • Jaydas Jan 08, 2013
    Fuse was blown, changed it. blower fan current is ok.
  • 33 Answers
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
Posted on Jul 19, 2008
SOURCE: Carrier Desert Master AC trips the fuse
1- check the fuse must support the current of the unit not less than (rla of the unit)
2- check freon pressure may below or toohigh causes compressor winding over heating
3- check fan motor winding
Posted on Sep 20, 2009
Testimonial: "Thanks so much, great and fast help..."
kel1guy2002
  • 3740 Answers
SOURCE: split ac runs for 2 hrs and MCB TRIPS
Hi and welcome to FixYa. I am Kelly
This is a sign of a compressor that has an armature dragging internally or the winding has a short to the chassis inside the compressor. Placing your hand on one with an internal short to the case will definately get your attention. USE a meter! (lesson learned the hard way too many times)
It really is not wise to keep trying to use the unit in this condition.
1. Higher electric bill
2. When compressor finally burns up and contaminates coolant system.... purging and cleaning the coolant system can be as costly as the compressor replacement.
3. There is a remote chance there is a chaffing wire from the outside unit to the inside unit. (Very remote)
A Service Tech will do a running check where he verifies the running amperage of the unit. High amperage = a bad / dragging compressor.
Kelly
Posted on Mar 02, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Onida split Ac H6 error
Onida split ac trip H6 error Showing
Dec 16, 2014 | Heating & Cooling
Ductless split
Not familiar with this particular unit, but whenever the breaker trips it indicates a problem with the compressor motor. Check it for a short or ground.
Sep 04, 2013 | Carrier Heating & Cooling
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
My carrier AC(model: Optima D plus) is displaying a error "E3". Can someone suggest a solution to it.
An E3 error on your thermostat (T-Stat) has the following description from your manual:
"Brownout condition or too low of voltage to thermostat. Double check wiring and check for
24 vac between R and C. E2 will clear 15 sec after proper voltage is restored."
If you are unsure how to check the low voltage to your t-stat, then please call a professional in your area to check the t-stat wiring and the transformer in your furnace.
Jun 13, 2011 | Heating & Cooling
Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
