Question about Bulldog Security Vehicle Parts & Accessories
I just installed a simple and easy 2030mc bulldog security talking alarm,I know its installed correctly cause instructions say if installed correctly,it then says"thank you",but the problem is,why doe
Instructions say to slide backing down and remove on remote,there was nothing to remove.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
  • 1596 Answers
SOURCE: bulldog remote start
Its a Fault in the Moduel and The Tech support Dont know How to Repair it I Installed a Bulldog Remote start/lock/tail gate on a 02 Blazer and 1 Year later it did the same thing, I just Disarmed it and forgot about it the Owner tried to get help from them to NO Avail.
Posted on Jan 20, 2009
SOURCE: programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Posted on Jun 09, 2009
SOURCE: My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Posted on Jun 15, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
How to get lights to flash on bulldog keyless entry
you have an aftermarket keyless entry system installed in your vehicle, if the bulldog module is not wired into your lighting harness under the dash with single stage relays then it will not give the lock/unlock flashing indication. if it is already installed correctly then check all connections to confirm good contact. if problem still occurs its either caused by a faulty relay or bulldog module.
Nov 10, 2013 | Vehicle Parts & Accessories
I need to know what remote controller to order.Type your problem for a solution...
http://www.bulldogsecurity.com/ It will come with instructions based on the one you buy for your car or just call them and ask.
Aug 22, 2017 | 710 P Replacement Remote for Alarm
Someone programmed their remote into my Bulldog 2010 alarm brain and is deactivating my alarm and then vandalizing my car. How do I get rid of their programming instructions and neutralize their remote?
Your model will only keep 4 remotes in memory, so in order to deactivate there remote, you need to have your remote programmed 4 times into your unit
Dec 17, 2009 | Basic Remote Vehicle Alarm System
I have installed a bulldog security rs82p on a 2004 merc sable. The bypass module used was originally labeled as a model 20402,23402,27402,&29402. This is now the 791 the unit turns on but does NOT...
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
Oct 25, 2009 | Bulldog& Remote Alarm System With 1-wire...
No instructions
You can find the instructions at the Bulldog website
Just click on Installation Manuals, both the Deluxe500 and the HON4 are there.
Oct 23, 2009 | Bulldog Deluxe 500/HON-4 Remote Starter &...
I have two remotes and only one will work
I don't know if you have the owners manual if not you can go to the website and find the programming instructions there.
Mar 27, 2009 | Bulldog Keyless Entry System
Vehicle Parts & Accessories Logo
21 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
