Question about Kenmore 73952 Gas Dryer
MY 10 YRS OLD KENMORE GAS DRYER HEST AT FRIST, THEN JUST RUNS AN
AS STATED AFTER THE FRIST SHORT HEAT CYCLE, THE DRYER JUST RUNS AND RUNS... WHAT,S UP .. WITH IT...
    President:
  • 1,214 Answers
The timer has probably failed, a common problem. Easy to replace.
Posted on Jan 20, 2009
My Kenmore Elite HE4 dryer keeps shutting off after a few minutes.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Jul 09, 2015 | Kenmore Elite HE4 Electric Dryer
I HAVE A AEG LAVATHERM 500 R TUMBLE DRYER 25 YRS OLD IT START RUNS ITS CYCLE BUT NO HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | AEG Dryers
My Kenmore gas dryer only heats for short time. The burner comes on initially for about 1-2 minutes then cycles off. Later, the igniter turns on, but the burner does not come on. I have cleaned the...
if the dryer runs and heats for a short time and then no flame you have bad gas coils,when they are failing they work until they heat up and cut out,when they cool down the heat will work again for like the first 10 to 20 minutes and then cut out again.take out the two phillips screws on top of the gas valve,remove the top cover and change out the coils,check the coil with the three prongs on it or check the post you pull it off of,there should be a spacer on the post,if you don't see it on the post look in the hole of the coil,if it's in the coil poke it out and slide it back on the post,easy fix
Jun 12, 2010 | Kenmore Dryers
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
appliancepartspros.com
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore 73952 Gas Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
