Question about Hitachi DV-PF33U DVD Player/VCR
The vcr works but the dvd will project picture on tv
I put the disc in the dvd and it shows loading but it never shows a picture on tv.I have tried L1 L2 and all channels but still won't show picture on tv.
BMW Rider
  • 232 Answers
SOURCE: yellowish tint on all channels
Hi, bad news guys, from your brief description you have a bad light engine, you both need to have a tech verify this but thats most likely what is causing your symptom. This is NOT a layperson repair, you`ll need a tech, BMW Rider
Posted on Dec 12, 2007
big raymo
  • 3 Answers
SOURCE: the camcorder works fine but
first remove your battery and connect the camcorder to the charging unit via the lead supplied...tunr on camcorder , wait till "access disc" is complete, then press the disc navigation button, then press menu, then use arrow keys on toggle switch to scroll down to capacity/finalize disc, sellect finalize , press toggle switch to finalize disc... this takes about 7 mins depending on disc capacity.. once completed your disc will play on your pc and dvd player no problem..... hope this helps you out ..... Raymo......
Posted on Jun 04, 2008
mrlobsterbob
  • 22 Answers
SOURCE: Color Problems with Hitachi projection screen television
check the bulbs
Posted on Oct 20, 2008
SOURCE: tv wont show picture
Got a new tv and didn't pay any online service for a "solution"!
Posted on Jan 09, 2009
electronick
  • 505 Answers
SOURCE: My TV has little green dots all over the picture.
You have the problem called "diffusion" errors, or some call it non-erasing pixels, etc.. You may be able to adjust the voltages to fix the issue. The 2 main voltages are VS and VA. The value they should be is listed on the back of the plasma panel. If one is off, then it could be the cause. Some manufacturers recommend turning up or down vs or va by 10% to fix this type of issue. Unfortunately, it can also be caused by many board in the tv.. power supply (where vs and va are generated) plus also the y and z drive boards, buffer boards, etc. If they are across the whole screen, suspect the power board and Y board most likely. I can talk you through all the adjustments but you will need a dc voltmeter capable of handling 250v. Let me know your skill level and we can fix this together.
Posted on Jan 29, 2009
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
I was able to connect a dvd player to old tv with a rf modulator.now is there a way to hook up a vcr on same rf modulator so as not to change connections each time you want to watch the vcr with instead of...
well...the reason its sooo hard is that this modulator is not intended for this use. its used for BIG jobs. you can normally do what you want with a simple rf modulator you buy at walmart or radio shack as it has a cable in and cable out, but
You dont even need a rf modulator.
The VCR can do it for free simply; hook the yellow , white if your vcr has red as well (depending on how old )...BOTH or all Three color to color from VCR(INPUT) to DVD
then use a piece of coax cable from the vcr out to tv.
test vcr by making sure that it work on either channel 3 - or 4 on tv. (leave VCR on)
Then to test your DVD connection first turn DVD player on.;.Then on front of VCR press channel down ON VCR until it says L1 or L2 this is under channel 2 when channel downing.
you should now see the dvd player on screen on either L1 or L2 depending on vcr.
now buy doing this your vcr must be on the L1 (L2) anytime you watch a dvd but when you want to watch a tape you just put it in and press play since TV itself is never changed.
when you want to go back to dvd,...stop tape and should still be right on the L1 or L2 again.
Aug 05, 2011 | Channel Vision E-1200 Video/audio Rf...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I have a go video vcr/dvd player. The vcr works dvd doesn't
if this happens to all discs needs to be repaired.my panasonic was playing up and not very old,and cost me $350.00 for a new driver.
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
How can I record a tv show onto a blank disc? I
Make sure you have the right DVD disc and the disc is clean if you do... (2) make sure you connected it right and are fully seated. LINE IN on your DVD-R is for the recorder part LINE OUT on the tv is to send it to the DVD-R If you done that try another RCA cable or two That should fix it
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Can't get toshiba vcr to work with toshiba TTP-61H95 and dvd
please make sure the cable from ur vcr is attach at V-OUT...and cable from vcr that attach to dvd is V-IN...to make sure vcr is displayed at your tv, unplugged cable from vcr-to-dvd to from vcr(V-OUT)-to-tv(V-IN)...
Jan 10, 2009 | Toshiba TP61H95 61" Rear Projection...
Dvd/vcr combo
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
May 18, 2008 | Televison & Video
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
Hitachi DV-PF33U DVD Player/VCR Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
