Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Audio cuts out intermittently and tv only 10 months old.
Have replaced Comcast Cable Box 3 times and it hasn't solved the audio problem. Don't know it the problem is the cable box or the tv!
  • Anonymous Mar 20, 2014
    I cannot get any audio, or video from our TV. In fact, we are not able to see any onscreen messages or prompts.
    We have tried disconnecting our cable box, DVD player...and we cannot solve our problems.
    I have tried pressing the input button from both the remote, as well as from the TV, but since we re not able to see any onscreen messages, we are lost.
    Any ideas?
    Thank you.
    Scott
    Sergeant:
  • 367 Answers
Hook the tv up without the box then use dvd etc to test the sound
If the sound works find with dvd etc hooked up then its the box
Posted on Jan 20, 2009
  • Rob Houg
    Rob Houg Jan 20, 2009
    If the problem continues I would bring the tv back to the store.l
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
The volume does not work on my phillips hdtv- solve
Try accessing the audio menu and be sure the TV speakers are turned ON. Good luck !
Dec 05, 2009 | Cars & Trucks
Audio drop outs when using HDMI connection on new Viera
The way I solved it was to go into advanced settings and change the audio input connected to the hdmi port to component. I had to run an audio cable from the cable box into the TV but since I did this we haven't had the problem.
Jul 13, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
BOSE LIFE STYLE SYSTEM SOUND (AUDIO) GOES QUITE FOR A SECOND
This was posted a while ago, so I'm sure it's probably been solved by now. For anyone with audio issues using this or any other Lifestyle system: If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
Dec 14, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sound cuts out- cable tv
I had the same problem when I installed the new HD Comcast cable box (DCH3200), initially with my CRT through RF, then with my HDTV through HDMI. Problem solved when I replaced the box with the Comcast RNG110 I got from my local Comcast. It is a neat miniaturized box and it works extremely well on HD. There is no power switch on the box so before activation do not forget to put it on with the remote (cable, power, the green light will come on).
Aug 09, 2008 | Sony STR-DE595 Receiver
Audio cut off Samsung 32
Try using different audio connections and see if you have the same trouble... try using RCA cables, optical, and HDMI... see if it happens in either scenario... I would bet dollars that you are using optical audio and the cable is crimped, etc.... you probably just need a new digital optical cable...
Dec 27, 2007 | Samsung LT-P326W 32 in. HD-Ready LCD...
Philips 50 inch Plasma - no audio on occasion
Try swapping the HDMI cable. They occassionally fail.
Nov 21, 2007 | Philips 50PF9630A 50 in. Plasma Television
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
267 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
