Question about Brookstone Stunt Copter RC Helicopter
How do you sync the stunt copter rc helicopter with the remote?
All of the batteries are new. The red light in the copter is flashing as it should and the remote is working. However, when I follow the directions in the manual, it will not sync. I get a short beep instead of a long one. Thanksl.
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Air Hogs R/C pocket-copter not functioning
your copter might have already experienced some hard bumps or landings , so you might need to check your copter circuit and battery cables to make sure they are in good condition or check the battery itself.
May 02, 2015 | Spin Master 1001130 Air Hogs R/C Pocket...
How do you turn on an HAK 311
On the copter right above the charging hole, there is a little switch. Left is off, right is on.
My copter has the problem that the remote doesn't work, turning it on does nothing, and connecting it to the copter only makes the light on the remote flash red.
HAK 31 is a piece of junk.
Feb 09, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
S107 charger light stays red all the time, doesn't change to green.
Check the batteries are new or in good condition. Also charging time is approx. 30 mins check in the manual how long charge time is. We also have replacement USB mini chargers available.
Kind regards, Julian.
rccontrolfreak.co.uk
Dec 05, 2013 | SYMA Toys industrial New Syma S107 Radio...
Wireing guide for a brookstone stunt copter
If under Warranty (Brookstone or Extended) have them replace it. If not, suggest a Hobby Shop that specializes in R/C Helis
Apr 17, 2013 | Brookstone Stunt Copter RC Helicopter
I want a manual for my stunt copter for the 4ch/2.4G
Just added it to this site. Should be up in 24 hours or so. Otherwise, go here: http://www.brookstone.com/webassets/pdf/796083p_manual.pdf
Dec 30, 2012 | Brookstone Stunt Copter RC Helicopter
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Brookstone Stunt Copter RC Helicopter Logo
952 people viewed this question
Top Brookstone Electronics - Others Experts
Are you a Brookstone Electronics - Other Expert? Answer questions, earn points and help others
