Question about Plumbing
Water ridge manual for 609030 pull out faucet
3 Suggested Answers
Bati99
  • 88 Answers
SOURCE: I need an installation manual
Call the customer service line (866) 789-2273
Posted on Apr 16, 2009
nielsonplumb
  • 91 Answers
SOURCE: water ridge pullout kitchen faucet.
That connection to the copper pipe is a olive with a nut that compresses it onto the copper, you need 2 spanners and the nut has to be done up thightly to lock onto the copper
Posted on Mar 09, 2011
I have a dripping WaterRidge NSF 61/9 . How do you fix this problem ?
On a water ridge kitchen faucet, there is a brass fitting that the water supply hose going to the faucet you pull out connects to under the sink, on that fitting youll find a small screw loosen it up, pull the fitting off , also loosen the other screw and disconnect the hose, now look inside the fitting there is some plastic junk ( not sure what its for) get a screw driver and a hammer and bash it out(not to hard) then put it back together. good to go, full pressure!! worked on mine and has for 2yrs.
Oct 25, 2017 | Computers & Internet
Have crane tap set , two taps and a spout with an in and out lever to shower or fill tub.I have no cold water when tap set is in place, when i remove the tap set from the fixture i have water flow.
Look inside the faucet handle for damage. A cracked handle would need replacing, as it cannot grip the faucet stem. If the ridges inside the handle are worn, the handle cannot connect with the stem and control the faucet.
Inspect the end of the faucet stem for damage. The tip of the stem should have ridges that connect with the ridges inside the faucet handle
Nov 08, 2016 | Home
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
Water Ridge kitchen faucet model FP4A4107NP does not swivel between sinks. I thought they all could be directed into either side of a double sink?
Did you install the faucet without using the top mounting plate? This could cause no spout swivel.
Dec 26, 2014 | Plumbing
Handle will not turn water off
single cartridge? pull old one, flush some water through empty valve then install new cartridge. once installed, make sure the horseshoe clip is properly inserted to keep the stem in. once the clip is in right, there is a chrome tube with a ridge that slides over the barrel and the clip. the ridge acts as the stop for the handle. also make sure there are stops inside back of handle to hit the ridge on the chrome tube. the plastic inside the handle may break off allowing the handle to spin. the stem unit/cart may also be installed 180 degrees out of place. pull the lock clip and use the remover tool that came with new cart to rotate it 180 degrees with water supply turned off.
Jun 17, 2013 | Moen & One Handle Tub & Shower Faucet
How remove handle for water ridge farcet nsf 61/9
Oct 20, 2012 | Plumbing
Water Ridge Nannini series pull out kitchen faucet rotating at base instead of where it should.
I just fixed our Nannini from Costco. The screens were plugged with plastic filings coming from our water lines. On our faucet there is more than one screen.
The pull out faucet has the basic screen like 99% of the taps out, right on the end. It comes apart by first unscrewing it from the handle and gently (gently) nudging the screen out with a sharp object such as a pairing knife.
Then in the handle was where the problem lay with mine. There was a plastic knob which is recessed in the handle. Leave the hose connected and pull it out until it is stretched or have a helper, then press on that small knob, pull and the whole inside will pull out. There is another filter in there. I was able to take mine apart and clean it, yes it does pop apart but be careful. In assembling mine I just left out the second filter totally.
I guess in hindsite you wouldn't have to actually take the whole handle apart if one has a 90 degree tool to pull out the yellow plastic piece. I used an allen wrench and pulled. Cleaned it with a small needle.
Works better than new!
Nov 24, 2011 | Moen Plumbing
Water ridge pullout kitchen faucet. I do not know how the plastic quick connect for the pull out hose line connets to the copper connector. i do what they say and it pulls off easily and leaks
Mar 07, 2011 | Plumbing
Apr 16, 2009 | Plumbing
Plumbing Logo
715 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
