Question about AOC 2436Vwa
Aoc 2436vwa no volume
I have plugged in my xbox to the monitor with an HDMI cable but there is no sound. It works on a normal tv with just the cable and the monitors volume is on full. Is there any way in which i can easily fix this. thank you
5 Suggested Answers
SOURCE: AOC model 1770 cable conexion
DIAGRAMA DE CONECTOR VGA
Posted on Jan 07, 2009
  • 68 Answers
SOURCE: AOC 19MVWK
CNET.com
Posted on Oct 24, 2009
SOURCE: i have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Posted on Dec 12, 2009
  • 4 Answers
SOURCE: Just bought an AOC 27" Class LED Backlit Monitor
the speakers are messed up
Posted on Sep 25, 2013
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
I want to connect my Xbox 360 to my aoc f22+ monitor so I bought a hdmi to d-sub cable to plug the Xbox into the monitor as it didn't have a hdmi input. The screen just shows a blank image and the only...
You need a HDMI to DI cable not HDMI to d-sub cable. The sellers that are selling that cable do not tell you that it will only work with special video cards that output analog to the HDMI connector. HDMI is digital and so is DVI so they will adapt to each other. Keep in mind that this is for video only, sound will not work on the monitor because the DVI port does not support sound. You will need to add a set of speakers to the Xbox
Aug 27, 2012 | Computers & Internet
I have an AOC L19WH LCD monitor. I am trying to get sound out of the monitors speakers but am having problems.
I can't find the model number you posted from the AOC website, so its hard to help you.
The only way you can get sound from a monitor is if you plug in the HDMI cable, this means that you need a graphics card with HDMI, very few computers have onboard HDMI.
Monitors that have speakers use HDMI and they need to be plugged into a HDMI port.
If you are using the DVI port, you will NOT get any sound.
You need to post the correct model number or a link to your manual, you also need to post what computer and what graphics card you have.
If you post this info, then someone can help.
The posts above are funny, a PSU has nothing to do with sound.
ODIEBUGS
Apr 05, 2012 | Computers & Internet
New AOC monitor. No sound . when i insert dvd which was in the package it just promotes AOC products
Did you plug the sound sable into the audio out port on your computer?
The VGA and DVI monitor cable/plugs do not have sound capability so if there are speakers on your monitor they need to get the sound signal through a separate wire.
HDMI can send sound so if your monitor is hooked up via HDMI it should be able to pass sound as well (at least in most circumstances).
Mar 12, 2011 | AOC Monitor
Have a new AOC 2436 VH monitor all hooked up and there is no sound. very frustrating can you help.
Vga does not provide sound over the cable. For sound to go to your monitor, you need to use the hdmi cable and only the hdmi cable. Also, make sure your computer volume is turned up.
Mar 02, 2011 | Computers & Internet
Yes , i have a proview 22 inch monitor and i connect it to my xbox 360 using an hdmi to dvi cable . the only problem is with the sound , it dont work what can i do ??i even try connecting speakers into the...
How do you connect the XBOX audio line out to the monitor audio input? If the xbox HDMI output is set to send the digital audio through the HDMI cable, you will not get the sound since you are using HDMI to DVI because the DVI is not made to accept the digital audio. You will need to to use the XBOX analog audio output instead feeding the audio cable with mini stereo phone plugs, please read XBOX user manual.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | Proview PL926WBi 19" LCD Monitor
How do i connect xbox to akura apl3268fd4 tv so its in hd
There are two ways to connect it.
1. The cable that came with your xbox should have two sets of plugs on it. One being the red, white, yellow and the other red, green, blue. You need to plug the red, green, and blue plugs into the tv with the same color plugs. You will also have to plug in the red and white for sound. The yellow plug is not needed. There will also be a switch at the base of the cable near the xbox. That needs to be set to HDTV. If your cable does not have the red, green, blue you will need to buy a cable that does have them.
2. You can use an HDMI cable. With that all you need to do is plug one end of the HDMI cable into the xbox and the other into the tv. Not all xbox's have the HDMI output though. If its new i should have it on the back of the xbox near the normal tv output slot.
If you use the red, green, blue you will have to set your tv on the component channel. If you use HDMI the tv will have to be on the HDMI channel
This will give you a more thorough explanation. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/audio-video.aspx
If you found this helpful please give me a good rating. Thanks hope this helps
Nov 21, 2010 | Video Game Consoles & Games
HDMI Problem
ok i think you need to reset the video settings here is a step by step procedure which you can follow
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  1. Remove any discs from the disc tray.
  2. Turn off the console.
  3. Turn on the console.
    Note If you are using an Xbox 360 Wireless Controller, turn on the console by using the Xbox Guide button on the controller. Wait for the guide light to indicate that the controller has linked to the console.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is indicated by the upper-left quadrant light on the console.
  4. As the console starts, press and hold the Y button as you pull the right trigger.
    Note This action causes the Xbox Dashboard to reset the display settings to the default settings. The console then automatically restarts.
Jul 10, 2009 | Microsoft Xbox 360 Console
HD DVI HDMI problems.
As long as the phono socket is red or white. That represents Audio
Feb 13, 2008 | Televison & Video
AOC 2436Vwa Logo
21 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
