Question about Dryers
My Kenmore 400 series electric dryer stopped working halfway through cycle, as if power tripped. There is however power into the dryer. What could be the reason? Did the cycle selector/timer blow?
  • Dryers Master
  • 8,220 Answers
It might very well be the dryer overheated. Look for blocked vent to outside(snow and such) lint and any other thing that could be causing an overheat situation. Next check the filter housing for blockage. then check the fuse. The fuse on these dryers is mounted on the blower housing near the exhaust and is right next to the control thermostat in most cases. Here is my page along with some home movies:
Paw Paw's DIY Kenmore dryer info.
Posted on Jan 08, 2013
  • 1 more comment
  • johan Jan 08, 2013
    Thanks Dan
    I checked the Thermo fuse with an Ohm meter, and found it to be disfunctional. Confirmed this by bridging the in and out wires to the fuse, and the dryer worked fine. Ordered a new new fuse online.
  • Dan Webster
    Dan Webster Jan 08, 2013
    Be sure and clean her up good so you won't have to keep from having to buy more fuses.
2 Suggested Answers
  • 63 Answers
SOURCE: Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Posted on Mar 16, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Electric dryer will not start
You do not say if the power light comes on? If not, remove the plug from the mains and check or change the fuse, putting in the correct value. Then try another appliance in the same power point and see if it works. If it does then try your dryer again. If not check the mains trip to see iit has tripped
Jan 27, 2014 | Kenmore 400 6943 Dryer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
Jun 21, 2017 | Kenmore 659 Electric Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
