Just moved int o a new flat and have 2 timers with no instructions and no makes of type. I took the front off to find what they where and found- GPT/1Digi20 and T55 R5H..but still no luck with finding them any where or the instructions.
    President:
  • 1,214 Answers
What brand name are either of these controls?
The T55 could be UK or US manufactured by two different manufacturers, and they are two different designs.
A search including the manufacturer will be a more successful search.
Posted on Jan 20, 2009
My Fujitsu air con keep flashing operation,timer and economy .off the plug took out and on back still the same.took out the batery from remote and put back still the same..plss help me
It's asking you what mode you want to run your unit in. Do you want to run it in heating or cooling (operation), do you want to run it with economizer mode (economy), or do you want to run it with a timer setting (timer). Do cooling, no economizer, and no timer. This will make your unit run off off the setpoint you want. I.e. 72 degrees
Aug 05, 2016 | Fujitsu Heating & Cooling
I would like to use the timer function that is available but no instructions came with this controller pad
you're gonna be there a while. Without knowing the name i cant even look int up for you. GOSH>!
Jan 28, 2011 | Heating & Cooling
Hello I need instructions on setting up the timer using the remote control for a RES 24C1 air conditioning unit. Hope you can help. thanks
There are 2 systems in timer set up. You follow as per your remote supports.
1. Set clock first. and then by pressing timer on make the time you need on. and same for off by timer off.
2. Press timer on which starts with 00.00. By pressing you can select how many hours after you want to switch on from current time and same for timer off. Is it useful? Write.
Dec 11, 2010 | Fujitsu 24C1 Air Conditioner
I have moved into a new house and there is a halstead quattro combi boiler but I don't have the instruction book and need to know how to set the timer on it
Can you please get a part number? I t might be on the outside of the unit. If not, you'll need to remove the front covers. There should be a nameplate with a model number, serial number, amp, volts, and other info. Let me know what that says.
Sep 28, 2010 | Heating & Cooling
Wall unit leaking water new installationseems to be drain line problem.
I had this problem once. I took the front cover off the wall unit and located the the drainage hose and found a build up of dust which was blocking the outlet.
Jun 17, 2010 | Fujitsu 18C1 Air Conditioner
Honeywell RTH230B
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jun 06, 2010 | Heating & Cooling
Took front of air cond. off today to clean and the 2 plastic clip tabs on rt side broke off. Can I get a replacement cover?
Contact the manufacturer of the unit to enquitre about replacement covers.
The easier solution is to use a typical 5/16 hex head screw just like found on HVAC systems everywhere, and replace the plastic tabs with the screws.
If the screws are not self tapping, you may want to predrill the holes in the metal first to make it easier.
Oct 24, 2009 | Heating & Cooling
Do I fill it with Water?
I don't know why but I kept the instructions -
Instructions are:
Lift the top cover and fill the smaller compartment with water - takes 11 litres from empty. Water level is seen on the window to the front.
Ice packs are placed in the larger compartment (That is all this compartment is for - Not to be filled with water)
Jun 30, 2009 | Heating & Cooling
Trane XE100 and I am getting an icing condition resulting in a shutdown. The fan apparently was operating but not moving any air through the room vents.When I took a panel off the fan assembly I got plenty...
Sounds like you are low on freon or you have some type of obstruction that is blocking the full flow of air across the coil.
Go for the simple thing first which is make sure you don't have something blocking the flow (like one time I found a plastic bag from the grocery store that had been sucked into the return grill and when the fan came on it would lay on the A-coil blocking the flow).
If that's not the problem then you are probably low on freon and should have the system charged.
May 18, 2009 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
