Question about Canon EOS 1100D / Rebel T3 Digital Camera
When i try to take picture built in flash will not raise get ERR 05, have turned the camera off like screen suggest does not work
    Novelist:
  • Canon Expert
  • 357 Answers
Usual cause is sticky liquid spillage around the flash pivots that cause it to stick or impact damage to top cover restricting movement of flash.
Cleaning with a toothbrush and water usually solves the former (do not put water on camera, make sure batter is out first). Dip toothbrush in glass of water (Windex also works good for this) and shake off excess then clean around the two pivots. Blow with a compressor hose or canned air to dry off. You may have to clean multiple times - let it sit a couple of hours and check to make sure you got all the sticky liquid off. Sometimes you have to disassemble the top of the flash and take off the guide plates. Be aware that there could be over 300 volts across the flash tube, make sure you discharge it with a 1K 5 watt resister before doing any work otherwise you will get a nasty shock. Discharge between the colored power wire and the trigger coil wire (may be covered with clear tape, carefully pull back tape to reach)
Posted on Jan 12, 2013
jackboy
  • 2985 Answers
SOURCE: built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
Posted on Jul 22, 2007
  • 641 Answers
SOURCE: Built in flash not popping up
Error 05 means - Something is obstructing the built-in flash.... Try to reclean it. Good luck!
Posted on Jul 31, 2007
SOURCE: Error 99 only when flash pops up
We ended up sending the camera in to Canon. $200 unless they find something more wrong. Luckily we have my Nikon D80 still. I will say that Canon replied via e-mail fairly quickly and one paid, said 7-10 business days for the repair.
Posted on Dec 09, 2007
SOURCE: Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Posted on Jan 10, 2009
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
I recently purchased a Canon EOS Rebel T3i SLR camera (July 2011) and already I am encountering a problem called "Err 05 the built-in flash could not be raised." Does anyone know how to resolve...
Hey Leo,
Unfortunately the problem you've mentioned is quiet common with your particular model.
Here's what Canon recommends, on its website.
-Turn the power switch to < ON > to turn on the power again.
And, if that doesn't work. Buddy, you'll have to drop by a service center. Hurry up, or you'll run out on the warranty period.
Toodles,
Rebel K
Sep 18, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Well, my flash doesn't always pop up. It has been working on and off and now will not shoot. It says "ERR 05" - keeps blinking that. Can you help?
I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this with the camera pointing away from me as if taking a picture. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether. (In picture 2 I show this plate removed and sitting in front of the mount only so you can see it removed, it was brought out backwards so towards me from the camera).
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
Dec 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
When taking pic an "err 05" (the built in flash was obstructed). On this camera eos Digital Rebel xti 400D. How do fix this?
The obstruction is often caused by the interior latch which refuses to move. If the flash cover ever opens, move the latch back and forward a few times which "sort of" re-engages it to its normal position.
Jul 03, 2010 | Cameras
My canon eos 40D keeps playing err-05 which says pop up flash not working and to turn camera off and on again to solve problem, but nothing happens and camera will not work. what can I do?
If the camera thinks you have an external flash attached to the hot shoe it will not allow the built in flashto pop up. so you can try this...
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Jul 03, 2009 | Canon EOS 40D Digital Camera with 28-135mm...
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Hi - I have a Rebel XT - and my built-in flash won't work - and i get an ERR 05 message. What can I do?
Dear joefrisco:
An ERR 05 message indicates that the camera's flash pop up mechanism has encountered a problem due to either an obstruction (such as your hand or something blocking it), a jam (impact damage), or an electrical failure.
Try the following steps, in order, to try and resolve the issue. If nothing works, the camera will have to be sent in for service (call Canon Tech Support @ 1-800-828-4040):
1. Turn the camera off. Ensure that nothing is blocking the pop
up flash. Turn your mode dial to one of the Creative Zone
modes (P, AV, TV. or M). Now turn your camera back on
and attempt to take a flash shot. You will need to manually
press the flash button to do so.
2. Turn your camera on and perform a hard reset by pressing the
MENU button, tabbing over to the Set Up 2 menu tab and
selecting the option "Clear Camera Settings / Clear All
Camera Settings" options, and then removing the camera
batteries, date/time battery, and memory card for a period
of approximately 2 minutes. Then reinstall all items, turn
your camera on, reset the date and time and perform step
number 1 above.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon Cameras
Err 05
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 1100D / Rebel T3 Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
