Question about Refrigerators
Loud popping sound every few minutes. Cools ok
    Genius:
  • Refrigerators Master
  • 1,669 Answers
Check the outlet plug. It might not be making good contact in the wall socket.
Posted on Jan 10, 2013
    New Friend:
Is your fridge self defrosting? We have one which makes similar noises (especially noticeable at night) and it's the defrost cycle.
I have been experiencing when playing LP's and CD's that I get a loud popping sound through the speakers, thereafter no sound then emanates until after several minutes when the sound comes back on.
It sounds like your amp is tripping a thermal cutoff. There's probably a bad component inside that is causing too much current draw, and overheating. When the thermal sensor cools down, it re-connects, and your sound comes back....but that starts the process all over again. You need to take the unit to an electronics shop for repair.
Jan 11, 2016 | Audio Players & Recorders
No Power after loud pop sound, is the power switch bad?
It is probably a bigger problem than the switch. If you are not experienced in working on electric appliances, you need to take it in to the repair shop.
May 23, 2015 | Nuova Simonelli Premier Maxi Espresso...
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
While watching the T.V. I started experiencing a random of two to ten second very loud static, popping sounds then it would go to a green then a digit scene then a gray w/loud sounds the popping sounds the...
Your set has a problem with its power supply. If it is under warranty, have it replaced ASAP. If your warranty has expired, you can take the set to any good repair shop - ask for an estimate before having any work done to it.
Feb 19, 2011 | Element Electronics FLX3711B 37 in. LCD TV
No picture after loud pop. Sound works fine
i have the same fault loud pop and no picture but sound is ok
Oct 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
02 silverado gas tank popping noise after startup & shutdown
It could just be the heat shield around your exhaust expanding and contracting again when your engine cools down. Sounds like a tin can type of popping noise?? If it is that's the heat sheild from the engine that protect's the spark plug wire and around under the truck cabin. Good luck and hope you find where the noise is coming from.
Apr 06, 2009 | 1999 Chevrolet K1500
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
AMANA REFRIGERATOR MAKES A LOUD POP!
Dear Customer
Please perform the following
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it. Please rate this,Thank u
Dec 17, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
