Question about Vacuums
I cannot get the belt onto the motor shaft on my sentria kirby vacuum
I have assembled and disassembled this belt 10 times and I cannot get the belt to go onto the motorshaft for the carpet brush to work
  • Vacuums Master
  • 18,424 Answers
Here is a video of belt change
Posted on Jan 08, 2013
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Posted on Jan 22, 2008
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
SOURCE: Kirby Sentria
If the green light is off, then its time to replace the band. This video shows you how.
Posted on Dec 30, 2008
Coleman37
  • 337 Answers
SOURCE: Belts on my vacuum last only a short time, the
The belt is either contacting the
1. Check to see that the roller is installed properly (make sure it is not reversed and that it is all the way in).
2. Check to see if there is any play in the motor shaft and that the motor has not come loose.
3. Check for wear on the roller where the belt contacts the roller. If this is worn you may need a new roller.
4. If the belt is still contacting anything besides the motor pulley and the roller at this point, you still have a problem.
Hopefully this will help. Let us know how you make out and good luck!
Posted on Mar 11, 2010
Tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My Kirby Sentria is not picking up with the power it normally does. Is there something I can do to correct this?
http://www.ebay.com/gds/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING-/10000000003800312/g.html
May 20, 2014 | Kirby Sentria Upright Vacuum
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Green light does not come on ans brush does not move. belt is good and brush does spin manually.
I assume this is a Kirby. The belt is not on the motor shaft if you can turn the brush manually. Remove the head, turn the belt lifter assembly clockwise to stretch the belt into a loop, place the head back onto the motor unit and latch it in place, then turn the belt lifter counterclockwise to drop the belt onto the motor shaft.
Jan 22, 2011 | Vacuums
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Was replacing the belt on my G6 Kirby and now can't get it reattached. Can't find my manual.
If it is any help, I usually put it on the motor shaft and then over the roller (which I have removed) and then replace the roller. I find this is easier on most models since you can then hold onto the roller (which is bigger) and have an easier time mounting the roller into the vacuum than mounting the belt on the motor shaft. Just make sure that you have the belt on correctly. The belt should only be touching the roller and the motor shaft, nothing in between. Hope this helps. Good luck!
Mar 13, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby sentria
remove the cloth bag from the bottom it twists counter clockwise, un clip the bag from the top remove the head piece, turn the belt lifter clockwise and release the lever to remove the head, take off the head, in your attachments there should be a screen that covers the impeller that the belt rides on it goes on like the brush head, put your hose onto the bag port by turning clockwise. there it is it will not work without the screen cover. thanks Rene
Aug 29, 2009 | Kirby G6 Bagged Upright Vacuum
Converting to shampoer
Starting with the shampooer brushroll,slip the belt over the brushroll,and install the brushroll into the bottom of tray.Install the brushroll housing over the brushroll,and looking thru the opening in the back of housing,turn the belt lifter counterclockwise untill the hook inside picks up the belt.Raise the height adjuster on the machine to it's highest settind.Install the entire assembly to the front of machine,and lock it down.Turn the belt lifter knob clockwise until the belt drops onto shaft.The elbow end of hose snaps into center of tray.There is a small plastic screen(size of a quarter)that fits onto the opening at tank.Without this screen,you wont get foam,only wet solution.There is a foam pad that must be installed at the air inlet opening at tank.Without this,dirt will enter tank,clogging it.Install tank onto blower side of machine.Lower height adjuster all the way down.You should now be ready to go.
Dec 15, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
