Question about Nikon D3100 Digital Camera
How to reset nikon d3100
Someone else used my camera and messed the settings up
  • 3289 Answers
SOURCE: have a nikon d70, lent it to friend who messed up
You can perform a two button reset. This can be accomplished by holding the BKT button and the metering mode button simultaneously for two seconds. Review page 111 of the D70 manual details which settings are restored to factory default after performing a two button reset. Custom settings are not changed.
Posted on Sep 15, 2010
Testimonial: "Very belated thank you! Much obliged"
Obertelli
  • 3006 Answers
SOURCE: Nikon D3100 brand new. I
The fault could be either defective batteries or a defective camera. All you can do is to try a full initial battery charge (24 hours) and if that doesn't work return the camera to the retailer for a refund or exchange.
Posted on Oct 08, 2010
  • 406 Answers
SOURCE: Nikon D3100 - how to
For Quick Response Mode and other Release Modes, please see "image1":
For remote control shooting or Bulb mode, see "image2":
image 2
Posted on Nov 24, 2010
  • 102366 Answers
SOURCE: Kodak 4GB SDHC Memory Card will work with Nikon
Yes. The D3100 will work with any SD card up to 2GB in size and any SDHC card up to 32GB in size.
Posted on Dec 18, 2010
  • 2386 Answers
SOURCE: What settings would you use on the Nikon D3100
Hello
Here are some general guidelines for shooting fireworks:-
Get a good position! Try to determine approximately where the fireworks will be bursting. And get a spot with an unobstructed view of that area. You'll probably need to show up early to get a good spot. Figure out the wind direction and get upwind of the fireworks so that your shots aren't obscured by smoke blowing toward you. Find a spot where you can avoid getting a lot of extraneous ambient light in the picture, as this will cause an overexpose.
Set the camera on the tripod. Don't extend the legs or neck of the tripod. Keep everything close to the ground to keep the camera as steady as possible.
Ensure the camera settings are correct. It is best to set these well ahead of time, as it may be difficult to see your camera controls or your checklist in the dusk or dark. But it's wise to double-check now.
Set your focus to infinity. You're generally far enough away from fireworks that you can adjust your lens focus to infinity and leave it there. If you want to get a closeup of a small part of the burst, you may need to adjust the focus as you zoom in. If you want to include buildings or people in the background, you may want to bring these into focus. Avoid the use of auto focus if possible. Most cameras have difficulty adjusting focus in low light conditions.
Use a smaller aperture. Set the aperture in the f5.6 to f16 range. F8 is usually a good bet, but if you're shooting with ISO 200 film you may want to kick it up to f16.
Turn off your flash. The fireworks are bright enough, and your flash wouldn't effectively reach them anyway.
Take off any filters or lens cap before shooting. If your lens has IS (Canon) or VR (Nikon),Turn it off before shooting. If you are shooting with an SLR or DSLR camera, chances are your lens has the IS (image stabilization) or VR (vibration reduction) feature built in. And if you have IS or VR (it is essentially the same thing, but Canon and Nikon just had to label it differently), then chances are you are used to leaving it on close to 100% of the time - which is generally a good idea. IS/VR is meant to sense the vibration (the shaking of you hands, mostly) and compensate for it. When it does not sense any, it... creates it. Turn it off in order to get sharper images. This tip goes not only for shooting fireworks, but is valid any time you shoot off a tripod.
Frame the picture before shooting. Look through your viewfinder during the first few bursts and figure out where the action is. Point your camera at that spot and leave it there. You don't want to be looking through the viewfinder while you're trying to shoot, because you'll likely shake the camera or your timing will be off. If you're trying to get closeups, of course, your framing will need to be more exact and you'll probably have to play with it more. Once again, frame carefully to exclude other light sources that might distract from the fireworks or cause your photos to be overexposed. 5Keep the shutter open to capture the entire burst. Set the exposure to the maximum length. To get the sharpest image it is best that nothing comes in contact with the camera during the exposure. Use the automatic long exposure of 30 seconds or more. If your camera does not have an automatic long exposure the use of a cable release is OK. Use the BULB (B) setting, which will keep the shutter open as long as the button is depressed. A rule of thumb is to open the shutter as soon as you hear or see the rocket shooting into the sky and to leave it open until the burst is dissipating. This will usually take several seconds.
Spice it up. Even good pictures of fireworks can be boring if there's nothing to distinguish them. You can make more interesting photos by including buildings in the background or spectators in the foreground. Choose your shooting location to try to get an unusual and unique perspective on the show if Possible.
Hope it helps, if so do rate the solution
Posted on Dec 27, 2010
Language set up
Push the Menu button. Scroll to the Setup menu. Language on that menu. Unfortunately the menus and everything else will be it the foreign language until you reset it. If you have trouble and can't figure out or find someone who knows the language your camera is set to, contact the Foreign Language Department at your local college or university.
Apr 10, 2014 | Nikon D3000 D3100 18-55mm
Arabic language
Go to Nikon website on your computer and download the language for your Nikon D3100 camera then use the usb cord to install it to your camera. Any problems with this go to ehow.com and they have other solutions too.
Aug 17, 2013 | Nikon D3100 Digital Camera
My nikon d3100 live view lcd screen wont come on. takes pics just cant review them or open menu
Hello, try to factory reset it, if still does not work and you will need to disassembly your nikon d3100 and change any parts i had found a official service manual that it will help, ypu can download it from the below link:
http://goo.gl/AvZHV
Good Luck
Feb 23, 2013 | Nikon D3100 Digital Camera
I have a nikon d3100 and some of the shooting modes are grayed out like picture control and if i press there is a message that says the options is not available with current settings what do i do??? i
Try resetting the camera by removing the battery for 15 mins. Replace the battery and go to the camera's Menu setting and set the Date and Time.
The camera should now be set to the factory default settings.
Jul 22, 2012 | Nikon D3100 Digital Camera
How do i set wide angle on my nikon d3100
You don't "set wide angle." Wide angle is not a function of your camera, it is dependent on the lens you use on your camera. You need a lens with a low focal length such as 24 mm.
Nov 03, 2011 | Nikon D3100 Digital Camera
How to reset to a factory setting a Nikon D3100?
http://support.nikonusa.com/app/answers/detail/a_id/17395
Aug 11, 2011 | Nikon D3100 Digital Camera
Nikon D3100 Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
