Question about Emerson Televison & Video
32 inch emerson flatscreen keeps blowing fuse when plug in and turn on. Have replaced it one time.
Watching tv and it just went off. Took panel off and the fuse was blown. 4amp 125v fuse. so went and bought a pack and put in and as soon as the power button is turned on it blows fuse. This is a 32 inch flatscreen model #LC32OEM2
Coldcut
  • 1554 Answers
SOURCE: sharp aquos lc26sh12u no menu screen appears
as you have a good screen, I would check ebay for the display controllers as there are so many available after shipment drops and kids with hard toys.
what you have been troubleshooting so far is analog , now its likely a digital issue , all you can look for is the the cpu is running,
is it getting the 5v + and the say 20 or so volts.
Posted on Feb 04, 2008
SOURCE: Sylvania 6632 LG blows fuse when plugged in
I too had this problem. I read some posts on this site about how to repair it, and low behold, they worked! I took the back off of the TV, and the first thing I found was the fuse was blown. With my meter, I checked the first 1N5406 rectifier diode after the fuse, and found that it had shorted out. Then I had to learn to desolder the diode, which I learned about on Youtube. I bought a pair replacement diodes at Radioshack for $1.49 and four replacement 125 volt 4 amp fuses. The whole repair cost about $5.00 and a few hours about learning about electronics. The TV works great! Good times!
Posted on Apr 08, 2009
a1electronic
  • 30 Answers
SOURCE: flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Posted on Jul 20, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Not turning ON, fuse blows.
In most cases, it is either a shorted component in the power supply or a shorted horizontal output transistor. It will take experienced electronic troubleshooting to fix it. TVs have lethal voltages (both 110V and 25,000V kind) and improper repair can result in shock, injury, or the emission of X-rays by the TV! Be safe and either replace the set or have a shop work on it for you. I'm a tech with over 25 years of experience, by the way. I appreciate honest rating of this reply if you find it helpful.
Posted on Nov 13, 2006
SOURCE: the tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Posted on Aug 15, 2007
My flatscreen Emerson tv keeps muting from time to time,most days it works fine but on some days it starts acting up again. What should i do?
Try unplugging it for a couple minutes and plug it back in, this will reset the tv's computer board. Make sure you turn it off before you unplug it.
Jan 01, 2016 | Emerson 32 Inch LED HDTV
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Why does my 32 inch emerson flatscreen tv Lc320em9 B stay on 3-4 mins then turn off by itself?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 27, 2015 | Emerson LC320EM9 32 in. LCD HDTV
How do you fix the loss of picture on a Emerson 32 flat screen
Hi Buddy,
There appears to be a problem in the Timing Control board. Please consult some local TV tech to do the job.
May 26, 2015 | Emerson LC320EM2 32" LCD TV 1366x768, 60...
Fix tv blowing fuses
when replacing fuses in a device....if, when you next apply power to the device and it immediately blows the fuse again : Do NOT put in anymore fuses. It is time to visit a TV repair shop.
Oct 30, 2014 | Emerson LC320EM9 32 in. LCD HDTV
There is no power getting to the tv. The tv just went off while watching it
if no stand by power indicator in the front panel it was an indication of power supply failure. replace blown fuse at the same time you must check other component that cause the fuse to blow. like shorted fet transistor and bridge type diode.
Aug 16, 2012 | Envision L32W761 32 in. LCD TV
My flatscreen won't turn on it keeps going red to standby
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Power supply looks like this:
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
Try to watch this video about capacitors and how to replace it...
I hope this solution will be helpful...
Thanks for using fixya...
Nov 22, 2011 | Emerson LC320EM8 32 in. LCD TV
Where is the lamp on my Emerson flatscreen tv
What ur tv problems?Tell me,i will tries to help u.Sorry LCD tvs or Plasma tvs don't have lamps.It have floorestscents bulbs tubes that are intergraded inside to the LCD or Plama screen panels itself.
Oct 16, 2010 | Emerson LC320EM8 32 in. LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
2,181 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
