Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Keep motor from turning over
I have a TB20cs trimmer and the cord broke. My question is, how can you keep the motor from turning over while taking the "star" screw out of the main housing unit?
4 Suggested Answers
  • 81 Answers
SOURCE: How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Posted on Jun 24, 2009
SOURCE: TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Posted on Aug 04, 2009
rycgl
  • 1545 Answers
SOURCE: Where can we find help
You will need to look at page 9 of the manual here. The string head installs part by part on the end of the driveshaft. If you are having trouble with the driveshaft turning while attempting to put the head on, post back. You shouldn't though if the end of the shaft's threads are in good shape. If you need to, spray some WD-40 on it prior to installation. Here is the manual.
http://dl.owneriq.net/c/c5ca28a7-c6a8-4dd0-8987-53c89193794e.pdf
Posted on Jun 08, 2011
Edging when heard a loud pop like a spring or cable broke while running at high rpm's, engine shut down.....now starter cord pulls freely. what's wrong?
Hi William:
This is fun because it's already broken so you can't easily make it worse.
I'd start by making a clear spot on the workbench and then start taking it apart. Label the parts, keep them organized, and maybe even take a few pictures as you progress.
Think of it as fun. Every bit you remove has a purpose, so try to check the functions as you go. When something doesn't do what you think it should, you've probably found the problem.
Sep 08, 2015 | Ryobi Expand-It 2 Cycle 26cc Trimmer Power...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
What is the oil/gas mix for my troybilt trimmer tb20cs
It is 40: 1 it says in your manual. That is 3.2 oz oil/gallon gas...or.....1.6 oz. oil/half-gallon gas
Here is also your manual!
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb20cs.html?idRes=183748
Sep 09, 2011 | Garden
Starter cord broke,repaired same but cannot get flexi shaft into head drive
it came from there so my only adviced is to keep trying. remember to regrease the flex shaft. turn while pushing shaft in.
Feb 05, 2011 | Ryobi Garden
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Primer Ball Sticking
Your carburetor needs cleaned. Disassemble the carb. and spray with carb. cleaner. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure that the small screen in the carb. is free of debris. Test the primer bulb after you get the carb reassebled and before you put it back on the trimmer. This will keep you from doing extra work.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Apr 17, 2009 | Craftsman Convertible 25cc. Gas Line...
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
139 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
