Question about MSI Computers & Internet
Not getting any video from a msi 880gma-e55 integrated video motherboard
I took an MSI 880GMA Motherboard out of an old Micro ATX case and Micro ATX power supply, purchased a new ATX case, power supply ( Thermaltake 430 Watt PSU ) and put the same motherboard, same CPU, Same RAM, Same Hard Drive, Same DVD, and placed them in the new ATX case, with the new ATX PS When i power the system unit on, I get no video coming from the Motherboard. I originally had the monitor hooked up with a DVI connector, and used the same connector and same power cord and when I powered on the monitor it says "DVI Input = no input signal", I tried replacing the cord using a standard VGA cable that is a known good cable, and it did the same thing "VGA Input = no input signal". Please advise...as I'm not sure where to go from here.... I used an anti-static wrist strap and anti-static mat while taking it out of the old Micro-ATX case, and putting it into the new ATX case. i took every precaution I could think of to make sure it would go smoothly...and here I sit clueless as to what happened...because just earlier today this motherboard was working just fine ? Please advise..... Thank you for your assistance. ~Matt
  • 2,878 Answers
This may sound simple, but make sure the monitor is set to correct input. Many are auto detect, but you never really know.
You could also check BIOS for onboard video. Disable if you have an add-on video card. Enable if you don't
Reseat the video card if it an add-on.
Posted on Jan 08, 2013
SOURCE: gigabyte motherboard wont post
Hi telme simple Problam to shot cut /?- ok what is this
Posted on May 17, 2008
you have pry more, you have to invoq the god in you life, becose
i't's not posseble.
Posted on Aug 19, 2008
tbirdfan1
  • 3051 Answers
SOURCE: new asus m3n72-d motherboard bios will not post
double check the bios jumpersmake sure that they are set to normal
Posted on Aug 23, 2008
shibuda
  • 1812 Answers
SOURCE: Asus M4A785-M will not post.
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Posted on Dec 12, 2010
  • 411 Answers
SOURCE: MSI 880GMA-E55 manual
Download here...
http://www.msi.com/product/mb/880GMA-E55.html#/?div=Manual
Posted on May 26, 2012
Will a msi kt4v motherboard work in a gateway gt4016 desktop
The Gateway GT4016 is a 6-Bay Micro uBTX Case and the MSI KT4V is a ATX motherboard. Therefore the Motherboard will NOT fit in the gateway Case.
Jul 07, 2014 | MSI KT4V (MS-6712) Motherboard
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
880GMA-E45......my cpu fan system not functioning,,,how to troubleshoot the error?..pls advice..
Try plugging the CPU fan into one of the other fan ports on the motherboard. If the fan still does not work, then the fan is bad. If it does work then the circuitry that controls the cpu fan speed is bad. You can try turning off speed control in BIOS and see if the fan works again in the cpu fan plug.
Jim
May 10, 2011 | MSI Computers & Internet
Where i can download this ms 6743 motherboard...???
You can download the device drivers from MSI WEB supportsite, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
May 04, 2011 | MSI 6743 865GM2-LS Micro ATX Pentium 4...
Multimedia audio drivers
You can download the drivers from MSI WEB support site,select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
Mar 01, 2011 | MSI RS480M2-IL ATI Radeon Xpress 200...
Hi I bought a 880GMA-E45 from Newegg and am having trouble getting it to work. The computer turns on, but I cannot access the BIOS menu because there is not VGA Signal going to my monitor. My monitor works...
Every time I've run across something like this that has just stumped me it has been either a bad part or some obscure jumper, like a FSB jumper. Interestingly enough, I looked at the manual on MSI's website. This model appears to have two DIP switches, they are on the bottom edge of the board near the PCI slot labeled something like "OC_SW1", make sure they are set both to the on position.
Feb 26, 2011 | MSI 880GMAE45 AM3 AMD 880G USB 30 Micro...
Video driver for windows xp msi-k8mm-v-7142
Jan 31, 2011 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Computers & Internet Logo
66 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
