Question about Mtd Troy-Bilt Bronco OHV Tiller
How to replace belt on a edger mod#25b554l731
Double pulley belt twists on to outer pully
Ac, altenator & crank pully alignment
The crank pulley is a 2 piece part, the outer pulley "ring" is insulated from the inner pulley by a special sandwiched rubber ring. The outer pulley on may "walk" off the inner pulley due to engine vibration, this is most common on 4 cylinder engines. The crank pulley is the only pulley that can do this.
Jul 17, 2016 | 2000 Toyota Camry
Can i tighten the crank shaft pully on a 99 chevy lumina
If that is the case, it is not the pulley itself that is loose, it is the outer ring of the pulley separating from the center hub. There is a rubber spacer in there that shrinks over time and allows the outer rim of the pulley where the serpentine belt rides to move either inward or outward. Eventually it leads to belt damage and breakage, and in worst-case scenario, the outer ring can come off the pulley entirely and can cause damage to the radiator or other parts. It cannot be repaired, it must be replaced as a unit. Do it sooner than later to save yourself grief.
Feb 02, 2016 | Cars & Trucks
My 2005 grand am is squealing badly, replaced idle pull didn't work, could crank pulley or water pump pulley be causing it
Hi Jason remove belt and turn all the pulleys by hand there must be one seizing. And check the crank pully some have a rubber damper that fails and causes the outer pully to spin on the inner one. Good Luck.
May 17, 2015 | 2005 Pontiac Grand Am
How do i get the A/C belt off of my 1996 caravan
If it is a 3.0 engine, you should have an idler pulley you have to loosen to remove the belt. You loosen the bolt in the pulley then turn the adjusting bolt.
Jan 18, 2013 | 1996 Dodge Caravan
What holds pully on shaft for lawn keeper blade
I have an old model Lawn Keeper gas edger with a 2HP Briggs and Stratton engine. It uses a 30" fan belt to drive the cutting blade and both pulleys have an alllen head set screw holding the pulleys to the shafts. The pulleys are cast aluminum and the set screw and shafts are steel so I find need penetrating oil and heat to loosen the set screw in order to push the drive pulley further on the shaft to make room to replace the drive belt.
May 17, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
Blade is turning wrong way
The blade drive belt on your MTD edger makes a half twist in its pattern. When the belt was installed, it was twisted the wrong direction. Remove the belt from the blade pulley and reinstall with it twisted the other direction. Before you start the edger again, visually inspect the belt and make sure it is not touching anything other than the pulleys.
Dec 21, 2010 | Yard Machines Red Edger
Cub Cadet mowing drive belt often breaks or jumps the pulley
sounds like possibly burrs on pully, or pully depth is incorrect, causing belt to jump.
Jul 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Show me how the belt should be run
Stick the idler in the floorboard, even with the motor pulley and have the idler wheel facing to the left of that motor pulley. Insert the non twisted belt into the idler between the cheapass metal idler pulley mount(have yer woman hold that drum up, make her proud to assist) and now yank back on the idler good nuff to get that belt looped over that motor pully. Then let that idler go so the tenshun on dat boy cause dat belt to stay all propah on dat pulley. Replace that front panel. 05cc3f4.jpg
Belt config
Feb 26, 2009 | Kenmore 62802 Electric Dryer
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Nov 23, 2008 | 1995 Oldsmobile Aurora
Mtd Troy-Bilt Bronco OHV Tiller  Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
