Question about Master Lock 1 12" Weatherproof Padlock
The lock is stuck in the lock mode not actually in the hole
The lock was accidently locked with the prong in the hole. Now it will not unlock. Any suggestions?
Ford explorer door lock
Mine did not have the keyless pad problem - but replaced switch after checking it with ohm meter - showed switch was electrically stuck in unlock.
Jan 31, 2014 | Cars & Trucks
My friend's 89 Volvo 760 Turbo steering wheel is stuck in the lock mode. What can I do to fix it?
ignition is locked,and will not turn over. do you have any suggestions on what the issue could be?
May 01, 2012 | 1989 Volvo 760
The lock button in the middle unlocks the unit and the code to unlock it is what actually locks it... how do I fix this?
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do? First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Feb 11, 2011 | Weiser Lock Locks & Locksmithing
1990 Honda Accord CB. When I shut the door I locked it at the same time. The door is now stuck locked but the popper is in the unlocked position. So it thinks it is unlocked when it actually isn't. Then...
You'll have to use a screwdriver. Stick it inside the locked latch on the door itself, the hole that holds it closed against the car body, then pry on it while at the same time pulling the door handle up to open it. The lock piece should swing open and your door should close and open normally again.
Jan 16, 2011 | Honda Accord Cars & Trucks
My Nikon Coolpix P80 4G memory has become locked
there is an actual lock on your card on the side very small see if you may have locked it on accident
Oct 10, 2009 | Nikon COOLPIX P80 Digital Camera
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
1998 e-150 power locks are stuck in the unlock mode
The rear door lock/unlock switch was the problem. When I took it apart, I found the wire connectors were corroded. I cleaned them up and it is now functioning well.
Jun 20, 2009 | 1998 Ford Econoline
Stuck on "lock"
this happened to me but i'm not sure it will work for you.. try to put the actual switch into lock mode (push it firmly into lock mode) then slowly push it back to the unlock mode.. if it doesnt work the first time try it a couple of more times. it worked for me..
Feb 24, 2009 | Creative Labs ZEN Vision:M Digital Media...
My lg vx7000 cell phone is stuck on vibrate mode. how do i fix this?
How to unlock my VX7000 LG? I accident locked it...
pls. help me to solve this problem.... pls.
pls. reply my post! pls.
Jun 25, 2008 | Lands Phones
GoVideo DVR4300 Player
There is a child lock button on the remote for the player. Just press it. Ray
May 06, 2008 | GoVideo DVR4300 DVD Player/VCR
Master Lock 1 12" Weatherproof Padlock Logo
20 people viewed this question
Top Master Lock Boating Experts
Mike
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Master Lock Boating Expert? Answer questions, earn points and help others
