Question about GE 24 in. GLD5860LSS Stainless Steel Free-Standing Dishwasher
GE dishwasher won't start
I have a GE MAX that's about 5 years old. The problem is that there is 2 lights (normal and heat dry) that are always on in the control pannel but when I push the start button the get it to work, well, it won't. I tried putting the braker off for about 15 min and turn it back on, but still nothing. The 2 same lights always come on when I shut the door latch but that's all it does. I also looked to see if the control panel was locked but the little lock that's showing beside the "heat dry" function isn't lit. I also tried to press that "heat dry" button for 3 secs like mentioned on the tech sheet to see if it would lock and still nothing. Also, I pressed on the start/reset button for also 3 secs and it won't do anything.
please help 'cause dishes is accumulating....big time!!
Thanks I also have a GE dishwasher although not the same model. It is brand new. It worked the first 2 times it was ran and then started doing the same thing. Every once and a while, after many, many tries, it will start. It will start about 1 out of every 50 times you try. The lights on the panel are lighting up but they do not respond when you push any of them.
SOURCE: GE Profile Built In Dishwsher won't start when you push the start
I turned off the power to the dishwasher for 10 minutes as recommended by a serviceman via the phone and then turned it back on and it reset itself and worked fine.....
Posted on Dec 26, 2008
  • 83 Answers
SOURCE: How do I turn off my GE QuietPower3 dishwasher
If you just want to shut it off, press the cancel button twice--If you press it once it will drain before shutting off
Posted on Sep 17, 2010
SOURCE: GE GLD5560 won't start
Although this post is old, I will help anyone else that is searching for the answer. I too had this problem but after looking at the schematics for this dishwasher, I could see where the problem was.
First, open the door and remove the eight screws that hold the inside cover to the front door on. BE CAREFUL. There are wires attached from the front panel of the door to the inside panel for the soap dispenser. Close the inside panel by slowly raising it up into its closed position and locking into place. Looking at the front panel from the inside, there is a black box at the top with a white PLASTIC PIN. This pin activates the "CLOSED" signal to the control unit. Push and HOLD the white pin DOWN until the system resets. If this does not work, you may need a new unit which runs about $6. After reseting the system, raise the front panel slightly and press and hold RESET/START for 5-6 secs. Now, with a second person holding the inner liner against the machine tightly, I started a cycle and it worked fine. Unlock the inner panel and slowly lower back down and replace the 8 screws.
It's really very simple 10 min fix. the reason this happens is due to the flawed design of the SWITCH PIN, which is not rigid enough. It tends to move side to side and become stuck. A better quality PIN assembly would solve this issue for GE forever.
Have fun.
Posted on Jan 09, 2011
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
  • 272 Answers
SOURCE: The panel on my GE
May I ask..Did you follow the directions about holding the heated dry button? if it locked..this unlocks it..
Posted on Jul 06, 2011
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
The GE Profile Dishwasher will not allow me to start without the heated drying light coming on. I want to wash without this headed drying at the end of the wash. When I try to turn it off it turns the...
Try pressing the "Start/Reset" pad hold it for 5 seconds to reset the dishwasher and wait 2 minutes. If the problem persists, reset (reboot) the dishwasher by turning off power to the unit at the house circuit breaker/fuse box for 30 seconds. Or if its pluged in below the sink like mine unplug and plug back in. Restore power and the dishwasher should function normally.
Aug 02, 2017 | GE 24 in. Profile PDW9800J Built-in...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Won't turn on
If the dry light is flashing you will need a new keyboard, if the clean light is flashing try this key dance
normal, heated dry, normal, heated dry
wait for the lights to come on and then go off, press cancel and wait 2 minutes, try a cycle. If it works and fails again let me know we can dig deeper to find out the root cause
Apr 24, 2010 | Kenmore 24 in. 17462 / 17464 / 17469...
I have a GE PDW8680 dishwasher. 5 1/2 years old.
sadly when doing DIY repairs you must be able to figure out how to remove and replace the parts. you could search youtube for a video
Oct 16, 2017 | GE 24 in. Profile PDW8680JSS Built-in...
You have a washer control board problem or a burnt connector or both.
Mar 17, 2017 | GE 24 in. Profile PDW9200J Built-in...
Dishwasher model 665
Ok got the solution from a very friendly rep at Sears. She was all excited because she has been out of telephone support for 2 years and just came back and remembered this problem from her earlier days. Her solution worked and she is now my favorite person in the world. Five stages...read them forst then execute!
1. Press Heated Dry 2. Press Normal 3. Press Heated Dry again 4. Press Normal again. At this point all of the lights on the dishwasher will illuminate. Now, the final stage is 5. Press Start. Worked like a charm
Dec 22, 2008 | Dishwashers
3 year old GE dishwasher dead!
Buy a different brand of washing machine. I suggest a front loading one because they use so little water and they are cost effective and actually pay for themselves.
Jun 09, 2017 | GE Dishwashers
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE 24 in. GLD5860LSS Stainless Steel Free-Standing Dishwasher Logo
56 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
